1966
Mota-Lita steering wheel with after market boss
hi all,
I have a fault with the horn push on my Mk1 mini. Its been working fine for 10 years and now doesn't work.
I have taken off the steering wheel and can get it to work by putting a screw driver between the central spindle and the collar, but it wont work when making a circuit with the wire pointing out the end (which the horn button meets).
I'm guessing the wire is damaged internally in the steering column, as there was an intermittent fault which would cause the horn to sound if you knocked the steering wheel too hard.
sounds like a steering column out job perhaps?
Edited by beardylondon, 06 February 2010 - 04:05 PM.
