Flip Front Fitting Got This Far Toay
Posted 16 April 2008 - 07:05 PM
Posted 16 April 2008 - 07:08 PM
Posted 16 April 2008 - 07:09 PM
Posted 16 April 2008 - 07:17 PM
it was fun i was a bit nervous at first but once i got going there was no stopping meWas it fun cutting everything to peices? I didn't get the front off ebay in the end... got too pricey for a man with no money! Good pictures of your progress, their really big
Posted 16 April 2008 - 08:51 PM
Posted 16 April 2008 - 08:59 PM
i might use hinges at a later date ,but at the moment using bonnet pins,bolted the brace bars to the front subframe and inner wings, 2 bolts hold the brace bars on the front subframe,one normal bolt and the other one i used the bonnet pin as the bolt.well,im hopefully picking my flip front up friday,im getting more nervous about doing it the nearer it gets time to do it,where are ypu going to fit your strengh bars,are you putting hinges at the bottom????
Posted 16 April 2008 - 09:03 PM
Posted 16 April 2008 - 09:18 PM
yes it is, looks ok dont you think?is that still in the gel coat??
Posted 16 April 2008 - 09:21 PM
Posted 16 April 2008 - 09:34 PM
thats ok good to share info with you, right going to use a 7 pin caravan plug and socket which cost me 3.80,because mines held on with bonnet pins it makes it easy to disconnect the lights etc so you can lift it off, yep going to spray it ,but i am tempted to leave it as i think it gives the car the rally look with attitude lol, keep the questions comingmore bloody questions,what about the wires to the headlights and / or indicators,are you using quick release connections,im planning on using gas struts of a hatchback boot to control and aid a smooth opening,yeh the gel coat looks good,you going to rub it off and paint,sorry to hijack your thread,just really interested
Posted 16 April 2008 - 09:39 PM
Posted 16 April 2008 - 09:41 PM
Is there anything else i can do at the bottom of the front rather than hinges or pins or should i just make the hinges rmovage from the front end so it will be completly removable
Edited by mighty mini jack, 16 April 2008 - 09:42 PM.
Posted 16 April 2008 - 09:44 PM
Posted 16 April 2008 - 09:47 PM
dont know there proberly is i would just make the hinge pins removable which i think they are any way, so you con lift it offJust thought i would ask in here rather than creating a new thread for one question.
Posted 16 April 2008 - 09:52 PM
