This is the Specialist Components fast road demo engine -as per the build guide
spec 1293cc/21253 pistons, 10:1 cr
BMW K100 8v head - NO PORTING!
std BMW cams
std 33mm throttle bodies
SC full conversion kit
SC ecu and loom
MED crank + centre strap
MED flywheel assy
Orange diaphragm/AP plate
helical box/drops
4 pin diff
3.44 diff
- as you can see a fast road spec engine
Now onto the curves - this is having your cake and eating it - the torque from 1000rpm is stupendous (no need for a plenum methinks!) all the way to 7500rpm+ the torque curve is flat. This was paramount of my idea of a fast road engine - driveability does not suffer but it still revs like a banshee to 7500 when required making it truly versatile. You will not get this power curve from a 5 port with similar ponies. It starts on the button, idles at 900rpm - will pass all current mot emmisions regs and your granny could drive it. On the road it is pure grunt any revs, any gear, flat or hilly!, it feels like a 1.6l not a 1293. If you're at Brigthon please fell free pop over for a look at the car and a chat.
Oh yes it sounds nothing short of awesome as well
cheers
John
