Compression Ratio
7 replies to this topic
#1 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 29 November 2008 - 06:08 PM
Hey guys,
Well ive got a 12g295 head, thats going onto my 998, and i know im going to have to work out the compression ratio to see if my head will need to be skimmed, and i was wondering a few things:
1. how do i measure the gasket compressed thickness - anyone got a figure for a 998 standard gasket?
2. how do i measure the area in the cylinder head, ive seen glass being put over this area sealed with grease, and water poured into the area, and the amount of water that sits in there is measured and this is converted into cc..is this a good method?
3. after this all i need todo is get the bore and stroke figures from the haynes (its got flat top pistons) and ive got all the info i need?
4. from this how do i work out how much will be needed to be skimmed?
Any help would be much appreciated
Alastair
#2 Ethel
  • 25,933 posts
Posted 29 November 2008 - 06:29 PM
Hey guys,
About 4cc's or trace the outline on squared paper, counts the squares and multiply by gasket thickness - measure the old one with verniers.
That's the way, use a burette/pipette to fill it. A flat bit of glass or perspex eliminates the surface tension and having the head dead level issues - parraffin also has less surface tension ( or a drop of detergent).
add on about .75cc for the ring land.
CR is swept volume + total chamber volume : total chamber volume
You could get a pretty decent guess by comparing with the spec of a standard engine
E spec A+ is 10:1CR with a 24.5cc in the head and spec the same as yours.
Alastair
998cc /4 = 249.5cc's per cylinder
let x be the total combustion chamber volume
for 10:1CR, 249.5+ x = 10x
therefore, 249.5 = 9x so x = 27.72cc's
27.72 - 24.5 = 3.22cc's in the gasket etc.
#3 liirge
liirge
  • 4,097 posts
Posted 29 November 2008 - 06:35 PM
Thankyou very much for that ethel! brilliant as always.
#4 Ethel
  • 25,933 posts
Posted 29 November 2008 - 06:40 PM
If it comes to getting it skimmed, specify the chamber volume you want rather than the amount to mill off. Then it'll be their fault if it doesn't work out :P
#5 liirge
liirge
  • 4,097 posts
Posted 29 November 2008 - 06:43 PM
Hee hee, nice tip ethel!
thankyou again!
#6 liirge
liirge
  • 4,097 posts
Posted 07 December 2008 - 06:10 PM
When i measure the Cylinder Head Part, do i put in a spark plug?
#7 icklemini
icklemini
  • 2,982 posts
Posted 07 December 2008 - 06:13 PM
yes
#8 liirge
liirge
  • 4,097 posts
Posted 07 December 2008 - 06:19 PM
goodo thought as much!
