Engine Lifting Brackets
11 replies to this topic
#1 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 10 August 2008 - 05:49 PM
First time for me of taking an engine out so just making sure beforehand,
What brackets do you lot use to hook up to the chains from the crane, towings eyes?
Also where are you placing them, or more importantly what holes are safest?
#2 Pauly
Pauly
  • 4,213 posts
Posted 10 August 2008 - 07:09 PM
You can buy the brakets from places like minispares, I just made my own, they attach to the rocker cover posts. Undo the cover bolts, fit the bracket and refit the bolts.
Paul.
#3 Kam
Kam
  • 4,140 posts
Posted 10 August 2008 - 07:25 PM
Nice one mate, I'll have looksy on their site
#4 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 10 August 2008 - 10:25 PM
Just get some high tensile rope and wrap it around a couple of times, should do the trick.
#5 Kam
Kam
  • 4,140 posts
Posted 10 August 2008 - 11:10 PM
'should do' or 'will do'?
First time mate, I'd rather do tried n tested methods.
#6 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 10 August 2008 - 11:15 PM
I've seen it done loads of times but never done it myself.
Maybe best to go for the brackets for a first time lift.
#7 sixwheeler
sixwheeler
  • 500 posts
Posted 11 August 2008 - 07:31 AM
I always found that the engine was not quite balanced on the crane when using brackets.
I always use a piece of rope now as I just find it much easier and quicker. A loop in the end put over the nose of the starter motor/cluch housing then up over the rocker cover and then down behind and up-round the manifold (far right hand branch). Back down and around a couple of times dependnig on the rope and you're done. keep it quite tight.
The engine is balanced perfectly.
If the engine uses a different manifold then I temp put on a cast one.
Edited by sixwheeler, 11 August 2008 - 07:33 AM.
#8 GraemeC
GraemeC
  • 7,418 posts
Posted 11 August 2008 - 08:47 AM
I use a single bracket on the centre front head stud. Engine seems well balanced with a slight backwards tilt which is ideal for slotting the diff under the rear of the subframe.
#9 Pauly
Pauly
  • 4,213 posts
Posted 11 August 2008 - 09:43 AM
Heres a pic of mine.
Paul.
#10 Asphalt
Asphalt
  • 2,173 posts
Posted 11 August 2008 - 09:50 AM
#11 minivanman
minivanman
  • 3,454 posts
Posted 11 August 2008 - 10:29 PM
Be careful lifting from the rocker studs, they bend easily :yinyang:
I've not got a picture of my new one yet, it bolts to the head studs at each end of the head. Much stronger, and like graemeC says, it tilts the engine forward so the diff clears the subframe.
*edit*
you can see it in this picture
Edited by minivanman, 11 August 2008 - 10:31 PM.
#12 Kam
Kam
  • 4,140 posts
Posted 11 August 2008 - 10:47 PM
I've ordered a couple of lifting brackets and as I've got time I'll try different positions on the head/rocker for balancing.
Strange though as some say use existing bolt holes and some say try the wrap-around technique?
I think the engine is meant to be light, i might just ask a couple of mates.....
:yinyang:
