Miglia Style Steering Column?
20 replies to this topic
#1 Ro8bieg
Ro8bieg
  • 1,581 posts
  • Local Club: Fylde Mini Club
Posted 05 May 2008 - 08:46 PM
Hi, iv been thinking about doing this for a wile.
Could i use everything from my original steering column to do this with one of these?
http://www.huco.com/...?p=true&cat=191
Could I cut it about half way, weld this on and make a new bracket to support the column?
I think this would give a comfyer driving position?
Anyone any info or ideas?
Thanks, Robbie
#2 nicklouse
  • 18,443 posts
Posted 05 May 2008 - 09:36 PM
interesting idea but seems to be a lot of work when the droplink works fine.
what are you trying to do? get a more vertical wheel that is not in you knees while you are not sat in the back?
#3 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 05 May 2008 - 09:38 PM
More like the more modern cars so the wheel is more horrizontal
#4 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 05 May 2008 - 09:53 PM
anyone know the diameter of the steering column?
been lookin at this too.....
lookin at the bored UJ's though, better fit....
#5 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 05 May 2008 - 09:55 PM
Not 2 sure, i can check to moro because iv not got a steering wheel on atm :P
#6 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 05 May 2008 - 09:58 PM
also do you use just one UJ as i was looking under the fiesta on friday and it has two joints which reduce the angle, this a better idea or would complicate things too much?
#7 1340 gt
1340 gt
  • 148 posts
  • Local Club: ?????
Posted 06 May 2008 - 06:41 AM
good luck with that!!
to get the benefite your after you will have to change the angle the rack mounts at go alomst verticle they have one UJ short piece of column then another UJ.
i doubt any other way would get you sufficient benefite and to do it your gunna need to modify all dash area and bulk head.
i no why your doing it but im just over 6 foot have a column drop bracket and bucket seats and can drive mine fine. i would like the steering wheel at a "proper" angle too but i dont seem to notice when i put my foot down and get going!!
#8 minislapper
minislapper
  • 1,957 posts
Posted 06 May 2008 - 07:12 AM
When messing with the steering wheel angle/column etc PLEASE don't forget that it was designed in such a way as to be safe in the event of an accident. You could end up making your car more dangerous and it could do you some very serious damage should you have a frontal crash.
#9 Jammy
Jammy
  • 25,397 posts
Posted 06 May 2008 - 08:14 AM
As minislapper says. The subframe, engine and steering rack/column are all designed so that in a frontal collision the engine folds underneath the floor (not into the bulkhead/your legs), and that the steering rack moves under the floor too, pivoting the steering wheel upwards and towards the windscreen, away from your face. Placing a universal joint into the column will remove this feature. Of course, it does depend on where the impact occurs. If you were to do this I'd advise full harness and bucket seats.
It can be done though. Z Cars use several types of universal joint, etc to move the wheel to a more horizontal position. It should take too much effort. You might need to elongate the hole in the floor for the steering rack spindle. Then just undo the steering rack U-bolts and allow the rack to rotate around. You should only have to use one UJ, and you may even be able to use the same drop link.
#10 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 06 May 2008 - 09:05 PM
I have got bucketseats and 4 point harness's to go in. i cant see why i would have to mod the bulkhead?
#11 1340 gt
1340 gt
  • 148 posts
  • Local Club: ?????
Posted 06 May 2008 - 10:52 PM
think i see more what you mean, i was thinking you were wanting the wheel at the same angle as a modern car. if you just want an improvment then the above should work fine with 1 joint. i still think 2 would be too complicated to make it worthwhile and safe.
#12 minislapper
minislapper
  • 1,957 posts
Posted 07 May 2008 - 06:47 AM
Whatever modifications you do end up doing, make sure you tell your insurance company. This is something they certainly would want to know about!!
#13 Wil_h
Wil_h
  • 3,244 posts
Posted 07 May 2008 - 01:17 PM
I'm not convinced about the safety aspect. sure in a very specific accident the theory might work, but in reality this is a 50 year old design where safety was not high on the agenda, and but a mini through a modern crash test and the steering column will be the least of your worries.
For my hillclimber I used Montego or Maestro column, all the splines are the same and it has 2 universal joints in.
#14 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 07 May 2008 - 01:18 PM
Do you have any pics of your column will?
#15 Wil_h
Wil_h
  • 3,244 posts
Posted 07 May 2008 - 01:19 PM
you can see it in the car here
http://www.twin-turb...s/IMG_0088.html
