I have just purchased a Lumenition Magnetronic Ignition System and a Lucas Sport Coil. Are the two compatable?
Im just worried as on the back of the Magnetronic's box it states that "These units will be damaged beyond repair if connected to an ignition coil with a static primary current greater than 6 AMPS. Coil resistance must be 2.5 OHMS or more and the coil itself must have a resistance of at least 1.5 OHMS."
And i cant find info regarding the specs of the Lucas Sports to check these!!!
Any help will be very appreciated as i dont want to blow up my ignition kit or coil!!!
John
