Seats That Fit In The Classic Mini
666 replies to this topic
#391 IainNeon91
IainNeon91
  • 1,287 posts
Posted 17 February 2013 - 05:02 PM
RS Turbo RECARO's
#392 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 25 February 2013 - 09:16 AM
Rear seat base shortened by about 10cm to give greater leg room. Seat back had a hole cut into the rear frame to sit over the Mini's hump.
Finally new carpet strips to the sides to cover bare metal.
Two days, job done
Have you got a pic and dimension of the hole you had to cut in the back seat
#393 mow
mow
  • 55 posts
Posted 25 February 2013 - 01:48 PM
Two days, job done
No sorry that was one picture I forgot to take. I cut a rectangular section from the rear steel plate to the height of the parcel shelf and roughly the width of the centre grey upholstery section, just enough for the bump on the mini to fit inside the seat against the foam inner.
Mow
#394 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 25 February 2013 - 03:55 PM
Two days, job done
Mow
Thanks for that, so its a fair size hole then
#395 mow
mow
  • 55 posts
Posted 25 February 2013 - 04:00 PM
Two days, job done
Mow
Yes a fair size lol!
I might still have the piece I cut out, I'll check and let you know
#396 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 25 February 2013 - 04:36 PM
Two days, job done
Mow
OK Ta
#397 toms
toms
  • 103 posts
Posted 25 February 2013 - 04:45 PM
RS Turbo RECARO's
GOOD TASTE! Exactly the ones I want to refurb
#398 rally515
rally515
  • 3,848 posts
Posted 25 February 2013 - 04:58 PM
RS Turbo RECARO's
I have these & plan to fit them in mine,any chance of a picture of the mounting system you have ?.
The stock subframes are not far from fitting from what i can see on mine as theres a L shape at thefront rails so you can still tilt them.
Any help would be appreciated anyways.
Clifford
#399 IainNeon91
IainNeon91
  • 1,287 posts
Posted 25 February 2013 - 06:31 PM
RS Turbo RECARO's
Clifford
Yeah no worries, i made a mock up plan of what i had to do.
IGNORE THE BLUE PIECE DOWN THE MIDDLE AS THIS ISN'T/WASN'T NEEDED.
Black dot's = Bolt's or Welds (your choice) I welded the outer black dots on the red bars and bolts/nuts on the inner ones.
Cheers,
Iain.
#400 rally515
rally515
  • 3,848 posts
Posted 25 February 2013 - 06:35 PM
Brilliant,thankyou very much lain. :thumbsup:
#401 Jayme 1275
Jayme 1275
  • 488 posts
Posted 25 February 2013 - 11:54 PM
RS Turbo RECARO's
are the rst seats narrow enough to slide past the rear bins?
#402 PaddyShepherd
PaddyShepherd
  • 687 posts
  • Local Club: BOGMOG
Posted 26 February 2013 - 01:56 PM
Looking at the measurements below, could anyone tell me if OMP donington's should fit? (They would have to be mounted behind the cross member!
#403 Jayme 1275
Jayme 1275
  • 488 posts
Posted 26 February 2013 - 02:30 PM
from memory cobra monaco's are 510mm wide and they fit with plenty of clearance past the bin, so these should be ok. dont take my word for it though.
#404 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 26 February 2013 - 03:10 PM
Providing you aren't too fussy of the seat position laterally, ie. are happy to move them inwards to clear the bins then anything up to about 580mm width at the rear will fit.
Also, most bucket seats taper back at the rear. Sizes listed are at widest point. General car seats are often wider at the back due to the adjuster mechanisms.
#405 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 26 February 2013 - 03:12 PM
So what we're saying is, providing i'm not a fussy tw*t they'll fit, without getting too close to handbrake etc? :D
Such a shame about no chance of rear access with those seats though.
