Rebore An Engine
Posted 15 September 2007 - 08:03 PM
i try to rebore engine in order to build a 1380 cc !
But i have got a big problem. Impossible to find a block able to be rebore
I used two engines 12he25 : but the result is porous cast iron !
On monday, i will try a 12a2a engine in order to succed to rebore this one.
My question is : why the shops never explain this problem when you buy pistons. It's very disapointed to use a lot of engines in order to succed to build a good engine.
Have you got informations about this problem ?
thanks for your fast help !
Posted 15 September 2007 - 09:13 PM
If you can try and find a 1300GT block/engine.
Posted 15 September 2007 - 09:25 PM
also helps with cooling, although i believe offsetting is for clyinders 2 and 3 as the gap is nearly nothing!
esp with 74mm pistons on the 1430!
Posted 15 September 2007 - 09:48 PM
Just keep hunting. Oh and a 1300GT block would be an Aseries I believe. I thought It was best to Keep things as large as 1380's to A+ but again,... this could just be another one of those " if you do the job properly it's no problem" things.
Posted 15 September 2007 - 10:01 PM
my bores are lines and ther 74mm....
Posted 15 September 2007 - 10:02 PM
Just out of curiosity, did these porous blocks have WFM 1024 cast in big characters on the front of the block just below the head??
There is another thread not long back discussing this very issue, mainly starting with a linered block, were these blocks linered??
The topic also discussed the offset boring process. Have a search and Ye shall find
Posted 15 September 2007 - 10:08 PM
why wouldnt you be able to get to 1380?
You have a linered 74mm block??!!!
Cant be much metal between cylinders 2 and 3, well not enough to tie in the sides of the block!!
Say the liners are 0.5mm (20though) thick, this would leave 1.5mm of original block between cylinders 2 and 3, not much atall.
Personaly i wouldnt trust it for high output.
Posted 15 September 2007 - 10:24 PM
but im pushin 120hp and 11(ish):1 compression
no problems at all after 10k!
Posted 16 September 2007 - 09:19 AM
I will try my last engine : 12a2a who must be a cooper carbi.
After, i dunno what to do... at this moment, i think to sell the car if this engine can't be rebored.........
Edited by seb79, 16 September 2007 - 09:51 AM.
Posted 22 September 2007 - 05:24 PM
Here is a diagram showing what you need to do to get big bore A-Series engines without braking into the oilways. The diagram is scanned from the David Vizard book, Tuning BLs A-Series Engine. The book is essential reading if you are planning to modify a Mini engine.
HTH
Posted 22 September 2007 - 05:27 PM
yeh was goin to say, you have to offset the bores,
I always thought that 1430s were a 73.5mm bore (same as 1380) but with a stroked crank?
Posted 22 September 2007 - 06:49 PM
Posted 22 September 2007 - 06:55 PM
well i got 74mm pistons and 84mm stroke crank(std 81mm) and 18cc dish = 1432cc
Your maths dont add up buddy
