What's the best way to remove an inertia bendix from a starter motor?
Inertia Bendix Removal At Home
blacktulip
, May 20 2020 01:12 PM
3 replies to this topic
Posted 20 May 2020 - 01:12 PM
Posted 20 May 2020 - 01:16 PM
I've only ever successfully removed and refit with the correct clamp tool....there's surprising amount of tension that needs containing...
Posted 20 May 2020 - 04:49 PM
I've done it before by using two large pairs of vise-grips (mole-grips?). Clamped the spring with a pair of the grips on each side. Got it just tight enough where I could remove the round wire clip on the end.
