Timing Plate - Paint Or Electroplate
12 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 10 February 2020 - 12:44 PM
Hi,
I am rebuilding a Metro 1275 A+ and have cleaned up a lot of parts using mild Citric Acid.
The Timing plate has come back to life, but has some pitting.
I was going to put it back on as it is but feel that it needs some protection to prevent rusting again, otherwise it will end up like this:
(This is not my engine - just an example of what it looked like)
So what's the best option - paint or electroplate (Nickel)?
I have noticed that some people paint part of the plate, as seen in a screenshot from Bill Sollis's Ultimate Mini Builder:
Or the whole plate as seen here from a MiniMania timing video:
Also in the MiniMania shot they have painted the entire side of the engine? I was going to leave this bare metal?
Edited by JonnyAlpha, 10 February 2020 - 12:57 PM.
#2 nicklouse
  • 19,055 posts
Posted 10 February 2020 - 12:51 PM
as you can see very little of it is actually open to the elements. i would not paint it  untill it has been assembled. as i would not want paint inside that area.
#3 GraemeC
GraemeC
  • 7,472 posts
Posted 10 February 2020 - 01:10 PM
Use a gasket as a guide to mask of the internal area - allowing the paint to stop under the casket (not at the outer edge)
Edited by GraemeC, 10 February 2020 - 01:11 PM.
#4 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 10 February 2020 - 04:33 PM
Ok thanks. What about electroplating?
#5 GraemeC
GraemeC
  • 7,472 posts
Posted 10 February 2020 - 05:14 PM
Yes, you could do that
#6 Floyd kraemer
Floyd kraemer
  • 26 posts
Posted 10 February 2020 - 11:20 PM
I faced the same dilemma when rebuilding my 1275GT engine and eventually zinc plated mine using a Frost zinc plating kit.
It was a bit big so had to plate it twice (one half at a time) but it worked really well and still looks good 5 years later. I just made sure the overlap was not on the visible part.
I was very pleased I did this and replated quite a few other parts during the rebuild. They polish up nicely once you get the timings right.
#7 drs
drs
  • 22 posts
Posted 11 February 2020 - 04:37 PM
i got fed up with masking and painting, so my last build i used the med anodised alloy one
https://www.med-engi...oy-timing-plate
paul
#8 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 11 February 2020 - 07:24 PM
paul
Yes I had considered that, but it's another £40 added to the build :-(
#9 nicklouse
  • 19,055 posts
Posted 11 February 2020 - 08:10 PM
Reasons not to paint the inside area. You have fasteners to tighten and adjust. This often lifts paint. Or initially just lifts and loosens it. Till it comes off and joins the oil.
#10 Floyd kraemer
Floyd kraemer
  • 26 posts
Posted 13 February 2020 - 09:22 PM
Thought I'd post a photo of my replated timing plate...
Attached File  Plated timing plate.jpg   57.7K   5 downloads
#11 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 13 February 2020 - 10:57 PM
Looks great. I hat did you paint the aluminium with?
#12 Floyd kraemer
Floyd kraemer
  • 26 posts
Posted 14 February 2020 - 09:08 AM
It was Eastwood Aluma Blast spray paint.
It covers well so only used one can for everything I did on the car.
#13 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 16 February 2020 - 09:22 AM
Ah Eastwood, I remember watching all the Eastwood Kevin Tetz spray paint tutorial videos.
I was going to get all the aluminium bead blasted, but that won’t protect it from corrosion. May just blast it myself with crushed glass and spray it.
