Clutch Cover - Engine Mount Thread/bolts
Best Answer nicklouse , 12 June 2019 - 09:06 AM
the wok to transfer case are 5/16 UNC
the marking lines don't indicate High tensile bolts just the grade. which in this case is a grade 5 which is a "high" tensile strength bolt. (8.8 metric equivalent).
some reading if you want
http://www.americanf...tric-technical/
Go to the full post
2 replies to this topic
#1 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 12 June 2019 - 08:41 AM
Hi, could somebody please confirm that the engine mount bolt holes on the bottom of the clutch cover are 5/16" UNC please ? Got one bolt here and it has three lines going out from the centre to the outside, from memory this means high tensile ? Is that correct ?
Craig
#2 nicklouse
  • 18,330 posts
Posted 12 June 2019 - 09:06 AM   Best Answer
#3 Dalek
Dalek
  • Just Joined
  • 36 posts
Posted 12 June 2019 - 09:48 AM
Thanks, superb answers :highfive: :D
Craig
