Fitting Fuel Tank
12 replies to this topic
#1 Pete - W.Sussex
Pete - W.Sussex
  • Just Joined
  • 91 posts
Posted 10 April 2019 - 07:23 AM
I am doing a semi resto on my 2000 Cooper ‘Classic’ and have stripped the back end to repair the boot floor and rear subframe mounting points in particular. Now putting it all back together but struggling with the fuel tank.
On the rear bulkhead behind where the tank sits there is a bracket welded into the bulkhead, just below the captive bolt that holds the tank strap. It has not been touched during the repair work. My question is, does the tank push upto that bracket which then acts as some form of support against the pull of the tank strap or is the seam of the fuel tank supposed to go the other side of the bracket which would then support the tank more against the body of the car?
At the moment neither option seems to hold the tank firmly against the inner wing and the filler against the foam padding around the base of the filler pipe. I probably have an issue with the strap bracket position as well - this has been welded back on to a new panel in the floor - but before I deal with that it would be good to know how the back of the tank should be located.
Hope that all makes sense! I have searched for insight on this without success so far....but I am a newbie.
Pete
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 10 April 2019 - 07:44 AM
Hi Pete, have you got the rubber strip on the boot floor for the tank to sit on too?
#3 Pete - W.Sussex
Pete - W.Sussex
  • Just Joined
  • 91 posts
Posted 10 April 2019 - 07:50 AM
Oh! No I haven’t. Another thing I’ve lost then - will have to have a search.
#4 jamesquintin
jamesquintin
  • 1,017 posts
Posted 10 April 2019 - 07:14 PM
The tank is only really held up against the body at the bottom right by clamp. The rest of the weight is on the rubber strip and around the hole. When I did mine I put the tank bak into check and it was fine:
This is where the bracket should be:
Q
#5 Pete - W.Sussex
Pete - W.Sussex
  • Just Joined
  • 91 posts
Posted 11 April 2019 - 06:23 AM
Many thanks.
I have found the rubber strip and will have another go. Wish I had done a trial fit before spraying!
#6 Pops_Guild
Pops_Guild
  • 363 posts
Posted 11 April 2019 - 11:42 AM
Any pictures of this rubber strip and where it goes ? I was thinking there should be something, I put in my own foam strip to stop the tank gauging the boot floor so much when put it in and out but if there's supposed to be something there 'officially' then that seems a good idea..
#7 jamesquintin
jamesquintin
  • 1,017 posts
Posted 11 April 2019 - 04:00 PM
roughly see it here
You want nice strong rubber, not foam
Q
#8 Pops_Guild
Pops_Guild
  • 363 posts
Posted 12 April 2019 - 11:00 AM
roughly see it here
Q
Thanks for pickie! Roughly how thick is that rubber piece? 2mm ? 3mm? more?
#9 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 12 April 2019 - 02:13 PM
Mines about 5mm thick rubber.
#10 Pops_Guild
Pops_Guild
  • 363 posts
Posted 13 April 2019 - 07:25 AM
Thank you! (by the way, nice work on your Mini fella, been following your posts!)
Edited by Pops_Guild, 13 April 2019 - 07:26 AM.
#11 Pete - W.Sussex
Pete - W.Sussex
  • Just Joined
  • 91 posts
Posted 13 April 2019 - 07:32 AM
Here is a picture of the rubber strip I finally found which seems to be the one for under the tank. This one is just over 3mm thick.
Attached File  C840D0A6-1C1E-4A60-A286-5C57CB5E4ED2.jpeg   83.53K   19 downloads
I’m still puzzling over whether the seam of the tank at the back sits against the bracket on the rear bulkhead or the other side (nearest the body of the car) as per my original post. Any clues on this gratefully received.
#12 GraemeC
GraemeC
  • 7,437 posts
Posted 13 April 2019 - 07:48 AM
The tank sits on the 'boot' side of that bracket
#13 Pete - W.Sussex
Pete - W.Sussex
  • Just Joined
  • 91 posts
Posted 13 April 2019 - 07:56 AM
Many thanks!
P
