Heel Board Question ?
Posted 30 March 2019 - 08:02 PM
Cheers and reassurance appreciated
Posted 30 March 2019 - 08:23 PM
I think you mean capive nuts....not 'capsulated nots'
They have the movement to allow for tollerances in size / fit
Once tight they should not move
Posted 30 March 2019 - 08:38 PM
Posted 31 March 2019 - 02:17 PM
Posted 31 March 2019 - 03:40 PM
Yes
If they are a captive nut they float in a cage so there is some wriggle room to allow for slightly different dimentions
Posted 31 March 2019 - 04:09 PM
Posted 31 March 2019 - 05:26 PM
I thought all of the nuts on the heelboards are welded in place. mine certainly were and that was a Heritage Heelboard. Makes no sense to have anchor nuts there due to the way they generally fail when abused.
Posted 31 March 2019 - 07:43 PM
Posted 31 March 2019 - 07:56 PM
Mine on my Heritage heelboard, i seam welded these to make sure they never spun.
Posted 31 March 2019 - 09:06 PM
Posted 31 March 2019 - 09:08 PM
Posted 31 March 2019 - 09:09 PM
Well mine were solid on the heelboard i took off, so with the jig i made they were templated over in the same position. Now if they come off there will be some serious damage.
Oh and i did offer up an old trunnion just to double check.
Posted 31 March 2019 - 09:21 PM
Posted 31 March 2019 - 09:40 PM
If they do spin I cut a section out of the sill just large enough to get a spanner in to the nuts. Ive also drilled a couple of holes above the bolts in the rear bins that are big enough to get the nozzle of the penetrating oil nozzle in.
Edited by cal844, 31 March 2019 - 09:44 PM.
Posted 31 March 2019 - 09:47 PM
Here are a few more pictures of ho they should look.
98D2F921-8DA1-40D6-856B-1FA68ABC62FB.jpeg 51.38K 1 downloads
E6018A71-82AB-4225-8681-8FDA3FA0E1CD.jpeg 52.69K 0 downloads
Now before you go changing anything are you sure it’s not just the bolt that’s loose in the threads of the captive nuts?
You should upload a picture so we can figure out quite what you e actually got.
