Coolant Passages In Block
8 replies to this topic
#1 unburntfuelinthemorning
  • 1,982 posts
Posted 28 March 2019 - 01:19 PM
Is it common to have coolant passages in the block face which are incorrectly positioned?
Is it even worth using this block as it looks like a problem waiting to happen?
#2 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 28 March 2019 - 02:51 PM
Think that is normal for a head gasket
#3 nicklouse
  • 18,577 posts
Posted 28 March 2019 - 06:33 PM
often.
#4 unburntfuelinthemorning
  • 1,982 posts
Posted 28 March 2019 - 08:53 PM
Not ideal though is it?
#5 nicklouse
  • 18,577 posts
Posted 28 March 2019 - 10:07 PM
makes no difference.
#6 unburntfuelinthemorning
  • 1,982 posts
Posted 29 March 2019 - 10:18 AM
So I shouldn't worry about coolant leaks from this?
#7 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 29 March 2019 - 11:02 AM
Nope.
#8 Ethel
  • 25,919 posts
Posted 29 March 2019 - 04:12 PM
I think it more a limitation in making the gasket. The sealing rings need to have enough metal folded over meaning the holes in it can't be as close to the cylinder as they are in the block. The gasket seals on the flat faces. The rings are to stop ingress between the copper faces.
#9 unburntfuelinthemorning
  • 1,982 posts
Posted 29 March 2019 - 08:17 PM
Thank you.
