Rebuilding my gearbox and I have questions on what bearings to order.
Using a standard A+ 4 synchro gearbox for the 998. As far as I know this is the list of bearings I need to order. Please check that I have the right parts in mind. ive included minispares part numbers for what i plan to order
1 double roller bearing - AAU1365
1 single roller bearing - ADU7619
2 diff bearings - AHU1856 (these are for either side of the differential right?)
1 idler gear bearing - TUK100320
1st gear needle roller - AAU1815
2 2nd/3rd gear needle roller - AAU1816
1 1st mortion layshaft roller - 13H9513
1 large layshaft needle roller - CHM141
MED also say to change the "spigot bearing" - https://www.med-engi...-spigot-bearing
Where does this go? I can't find this on minispares.
Edited by BaronVonchesto, 21 March 2019 - 03:15 AM.
