Twin HS4 alloy inlet manifold
Bought this a while back to use, but ended up with a different manifold so may as well go to someone who will put it to use.
I bought it damaged and have repaired it. Essentially one of the lugs where it bolts to the head was damaged so this has been TIG welded back on and ground down. You could go at it a bit more if you really wanted to, but it's purely cosmetic and can't be seen once fitted to the head. I don't think this manifold has ever actually been on a head so technically is new.
One of the studs is missing too....cheap and easy to replace.
See photo's, what you see is what you get..... and any questions just ask
Located near Macclesfield if you are collecting.
£45 posted.
Edited by rally1380, 16 August 2018 - 12:04 PM.
