Metal Fuel Pipe
Posted 02 March 2018 - 01:45 PM
Just looking to replace the fuel hose under my car. Just like to confirm I can use 6mm microbore copper pipe. Something like
http://www.plumbers-...6030-4819-p.asp
Was going to purchase 3 metres. Or does the pipe need to be a special type
Thanks in advance
Posted 02 March 2018 - 02:05 PM
As long as its 6mm internal bore, then it shouldn't be an issue.
Posted 02 March 2018 - 03:37 PM
Posted 02 March 2018 - 05:13 PM
Posted 02 March 2018 - 06:01 PM
I've never actually replaced the long fuel pipe, but is it possible to put a slight flare in the ends of the pipe? Would make the rubber connections more secure.
Posted 02 March 2018 - 06:41 PM
But a bubble flare is probably more than you ll ever need.
Posted 02 March 2018 - 07:50 PM
I thought it was 6mm or 1/4 inchI use 8mm microbore then jubilee clip fuel hose to go over the subframes and to the tank
would 8mm be ok for a standard 998 and what are benefits of 8 over 6?
I was planning to use fuel hose to connect to tank.
Edited by Steve8274, 02 March 2018 - 07:50 PM.
Posted 02 March 2018 - 10:04 PM
There is no benefit from having 8mm over 6mm and you don't need to flare the pipe ends.
The standard 6mm pipe is fine and fuel pressure is less than 5 psi from most pumps so flared pipes are unneeded.
Some of the standard pipes and hoses from mechanical pump cars have no flares or clips
That said I would always use clips unless its one of those with the standard no clip pipes.
Posted 02 March 2018 - 10:17 PM
Posted 02 March 2018 - 11:29 PM
I don't think anyone specifies 6mm ID or OD as it does not matter.
Pm me I can do copper or cunifer (copper nickel iron alloy)
Posted 02 March 2018 - 11:43 PM
