Bonnet Types
8 replies to this topic
#1 malc_west
malc_west
  • 241 posts
Posted 24 September 2017 - 07:33 PM
I've got a mini 30 which I understand is mk 3 shape but I'm looking to replace the bonnet with a none lipped version my understanding is a mk 1 bonnet/replica will not have the lip and fit my car no? Currently the whole front is cut off to the inner wings which may need done as well so I can change the bits I need
As always thanks in advance for any help
Edited by malc_west, 24 September 2017 - 07:33 PM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 24 September 2017 - 07:36 PM
A MK1 bonnet will not fit a MK3 and later car due to the hinge location. if its a MK3 bonnet that has had the lip removed then yes it will fit.
It is very easy to make a MK3 bonnet look like a MK1, jsut simply and carefully drill out the spot welds that attach the lip, job done.
#3 malc_west
malc_west
  • 241 posts
Posted 24 September 2017 - 07:48 PM
So miss guided I cut the lip off flush with a grinder is that now ruined mate?
#4 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2017 - 07:51 PM
Is there still a piece left attached to the bonnet?? if so that is is the part that is spot welded on.
#5 malc_west
malc_west
  • 241 posts
Posted 24 September 2017 - 08:00 PM
Yeah I think so it'll finish in like a half cresant moon shape ?
#6 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2017 - 08:02 PM
Yes it will look like this
#7 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2017 - 08:04 PM
The above is a very heavily modified pattern bonnet. That came with hinges for either MK1 or Mk3, you just delete the hinge points you don't need. It was a shocking fit and took me a lot of work to get right. My lad could not afford another bonnet so i made the bugger fit.
And i removed the lip.
#8 malc_west
malc_west
  • 241 posts
Posted 24 September 2017 - 08:08 PM
Brilliant mate you seem to know all things mini.. il have a go
#9 malc_west
malc_west
  • 241 posts
Posted 24 September 2017 - 08:19 PM
