My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 08 January 2017 - 03:56 PM
Very pleased with my AMC Cub bought yesterday. Been umming and arrring about what to create. Sleeper,Rat look, military or all the above. Perhaps a super charged, desert rat look!
Attached File  20170108_124626.jpg   155.3K   70 downloadsAttached File  20170108_124611.jpg   91.07K   44 downloadsAttached File  index-3.jpeg   139.16K   45 downloads
A kind of moke hummer
Attached File  2017-01-08-15-55-29-2073354424.jpeg   9.74K   25 downloads
Edited by HUBBA.HUBBA, 25 July 2017 - 09:29 PM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,087 posts
  • Name: Neil
Posted 08 January 2017 - 05:23 PM
Supercharged desert rat look does it for me.
#3 CUBBACUB
CUBBACUB
  • 14 posts
Posted 24 January 2017 - 12:14 PM
I like it, Get it on the road quick! You don't want anyone in the same town as you driving a Mokealike first
#4 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 February 2017 - 04:42 PM
One of the first jobs I need to do is put some new brake lines in.I want to declutter the engine bay and move away from the yellow label tandem cyinder and put a cleaner looking single master cylinder in. Can any one tell me what rear pressure reducer I would need. The one that I think I need are out of stock at mini spares http://www.minispare...px|Back to shop
#5 nicklouse
  • 18,719 posts
Posted 08 February 2017 - 04:45 PM
get something like this
http://www.cjponypar...g-valve/p/BPV1/
 as I guess the rear is lighter than normal an you can also increase the braking if loaded.
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 February 2017 - 06:36 PM
I was looking for the original part. Out of interest, being lighter at the back would you put more braking power to the back or less?
Edited by HUBBA.HUBBA, 08 February 2017 - 06:37 PM.
#7 nicklouse
  • 18,719 posts
Posted 08 February 2017 - 07:29 PM
You are mot putting more or less braking power anywhere. You need to restrict the pressure to the rear. Or limit the pressure to the rear.
The power comes from your foot. To much at the rear and you will spin.
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 February 2017 - 09:16 PM
OK Perhaps I worded it incorrectly. Meant which has more / less pressure! Visavis is the back to be made more or less efficient. So a lighter car at the back is more likely to lock up at the back?
Edited by HUBBA.HUBBA, 08 February 2017 - 09:16 PM.
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 April 2017 - 07:29 AM
Thought I would get a couple pics up now I can finally get started on things.
Attached File  20170411_195140.jpg   44.41K   46 downloads
Bulk head sprayed ready to fit brakes and clutch hydraulics
Attached File  20170410_165725.jpg   86.65K   57 downloads
Sprayed up my shiny new wheels, now desert sand colour. (Slightly bigger than the black minilites) just the look I'm after now to buy 2 more rally tyes and get all 4 corners raised
Attached File  20170412_083147.jpg   37.12K   16 downloads
Edited by HUBBA.HUBBA, 12 April 2017 - 07:33 AM.
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 April 2017 - 03:06 PM
Being as I am supercharging, the first job is the brakes. Been a bit slow and fustrating today. But got the master cylinders in, most of the the new brake lines and refurbished calipers with green stuff pads and grooved/cross drilled discs.
Forgot to buy a regulator valve. Also decided to get new rear mini fins
Attached File  20170415_103836.jpg   45.69K   12 downloadsAttached File  20170415_145412.jpg   46.16K   16 downloadsAttached File  20170415_145417.jpg   36.71K   28 downloadsAttached File  20170415_145429.jpg   50.01K   21 downloads
Attached File  20170415_145633.jpg   65.67K   15 downloads
I could not get over how thin the left hand brake disc was. I have never seen this much wear in my life.it was about 5mm thick!
Attached File  20170415_105740.jpg   48.28K   35 downloads
Edited by HUBBA.HUBBA, 15 April 2017 - 04:55 PM.
#11 Ethel
  • 26,098 posts
Posted 15 April 2017 - 03:29 PM
If the back's lighter the tyres have less friction so it's easier to lock up under braking. I'd go for an inertia brake valve, I think it's what Mokes had, vans certainly did, it adapts to load and braking effort better than a pressure sensing valve.
Will a Mini based Hummer be a Mummer?
#12 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 15 April 2017 - 11:19 PM
Hummi?
#13 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 16 April 2017 - 07:38 AM
That's close to what I originally thought 'Hummini'
#14 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 18 April 2017 - 07:03 PM
New package from Stuart arrived today! I like the colour in the flesh, kinda bronze which'll go quite nicely with the desert sand colour scheme.
Attached File  20170418_195622.jpg   50.09K   66 downloads
#15 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 April 2017 - 10:14 PM
Been looking at reg plates and the nearest thing I can find to 'desert rat' is DE58 RAT. 'DES ATE RAT' is that desperate or cool ? PS on black and silver plates
Edited by HUBBA.HUBBA, 23 April 2017 - 10:14 PM.
