Steering Rack Overhaul - Uk Type Mkii
22 replies to this topic
#1 Spider
  • 15,198 posts
Posted 12 November 2016 - 06:19 AM
I've put this together as a guide for overhauling the UK manufactured and fitted MKII Steering Racks.
As this involves Steering on your Mini, if you are at all unsure or uncertain about any of this, then don't try it on. Overhaul at your own risk!
Ksd3gnY.jpg?1
I'm not exactly sure what years this particular Rack covers, however it would appear it was a 'popular' type of Rack, from various documents it would appear that these were first fitted in 1967 and went on right to the end, however I have come across a few other UK types that appear to have also been OEM.
To assist with this particular Rack, here's some identifiers
and of course, the fabled Plastic Plug
First job is to remove the Boots. Caution, it maybe filled with Oil, so you'll want to be prepared for that and a means of draining it. This particular one was loaded with Grease, which I understand was done in the factory for a while
This particular Rack came from a late Australian Moke, so it's been modified at our Factory with Lock Stops
For most Mini application, just ignore these throughout this thread, however the later cars that were fitted with 13" wheels from the Factory were fitted with a similar stop.
After removing the Boots and Draining any Oil, next job is to remove the Tie Rods. I have a Pipe Vice for holding the Racks to make this (and a few other jobs) easier, however, you could also use some shaped timbers in a vice so you can grip the Rack Body without crushing it or damaging it.
Part 2 to follow
#2 Spider
  • 15,198 posts
Posted 12 November 2016 - 06:25 AM
Then undo the Lock Nut. The correct Tool is actually a 'C' Spanner. Here's mine!
If you don't have a suitable C Spanner, you can usually get away with using Vice or Mole Grips, just go easy so you don't squash them. Here I have a set on the Lock Nut
and here (I've removed that set from the Lock Nut for clarity) on the Main Nut, NOTE I've only gripped by the lower section, this is important!
Loosen the Locknut while holding firm the Main Nut. Note that it will need some force as these two nuts are not only tightened up but also 'staked' together.
Once the Locknut has been loosened, the Main Nut usually comes off easy
Jumping one step ahead here, under the Main Nut is the Tire Rod Ball Seat careful you don't loose or damage it!
Undo the Tie Rod Main Nut all the way off
Then carefully lift out the Seat, careful though not to loose the washer under it!
and the Spring
Remove the other end the same way.
Next up, remove the Plastic Plug so it doesn't get damaged
part 3 coming up......
#3 Spider
  • 15,198 posts
Posted 12 November 2016 - 06:30 AM
then undo the Yoke Plate. Careful! There's shims under there
NOTE the length of the Bolts here. We'll come back to these at a later point
Now we remove the Yoke. To aid in this, push the Inner Rack as shown and it will pope the Yoke out just a little, enough to grip and pull it by.
Out it comes
There's an O ring fitted to the Yoke to seal it up
Not the best idea, but that's what it is
and the Yoke
Yuk!
OK, next Up, we can remove the Pinion Assembly. Undo these Bolts
stay tuned for part 4,,,,,,
#4 Spider
  • 15,198 posts
Posted 12 November 2016 - 06:35 AM
Note the length of these Bolts;-
Similar but ever so slightly shorter than those from the Yoke, as seen here
When re-assembling, be sure to fit the right Bolts back in the right location, or the Rack will lock up and it'll take you days to work out why!
Note that this cover has a gasket fitted. 999 times out of 1000 I've found if treated carefully, they can be re-used. I do this, not so much to be 'tight' but the exact thickness of these Gaskets affects the Shimming of the Pinion Bearings and 999 times out of 1000 these don't need re-adjusting, so if re-assembled as found, most times you'll find that the shimming is OK and you don't need to go hunting for shims, which are NLA.
Gently push on the Pinion and the Shims and Spacer will come out first
It may at first look like 2 thick spacers, but there's a few shims and a thick spacer in there when prodded
keep pushing the Pinion, and the Lower Bearing will come out
Then keep going and the Pinion itself will come out
Note that some Racks also have a separate spacer on the shaft end of the Pinion. This was added when the teeth of the Pinion were shortened.
Then the Inner Rack can be withdrawn from the Body
part 5 on the way,,,,,,
#5 Spider
  • 15,198 posts
Posted 12 November 2016 - 06:46 AM
At the Passenger's end, there's a small Phillips Head Screw, Remove that
It's purpose is to hold in the Bush, which is in here
One way of getting that Bush out is with a long bent rod, viz
Inserted from the Driver's end and until it lands on the Bush,
and a couple of light taps. the Bush will come out
The Bush itself is mounted in to a Pressed Steel Housing. While new Bushes are obtainable, you'll need to re-use that Housing, so don't damage it.
The rolled over end faces the outside when fitted.
At this point the Outer Race of the Upper Pinion Bearing can be removed.
To make life much easier, heat the Rack Housing in Boiling Water for about 5 - 10 minutes - I don't recommend any other way of heating it.
Then bang the end of the Housing down hard on some timber.
Last job remove the Pinion Oil Seal
So, now you should have it all in bits.
Give everything a really good clean up. After De-greasing all the parts, I Wire Wheel them so I can Inspect them.
Here's the Pinion. I've inserted arrows to show what really needs to be looked at in high detail, I usually use a magnifying glass and do it in the sunlight
NOTE that some of the later Pinions have a separate spacer on the shaft end of them. This was to make up for a difference in length when the teeth were shorted. This was done to assist with assembly on the production line, not that it will matter to us here, only, if replacing the Pinion, watch out for this, or you may end up with a Pinion that you can't get the cover over or one that rattles around loose that can never be shimmed..
The part that the Seal runs on needs to be blemish free. As much as it's there to keep Oil in, it's also to keep water out. The Teeth of course need to have no wear and no cracks.
If any cracks are found, then I'd recommend in the strongest terms to scrap the entire rack as it's clear that it's had some abuse, the extent of which would likely largely be unknown.
Also, the ends of the Teeth that locate against the bearings.
The Inner Rack
Again, the Teeth need a good looking at in the same way as the Pinion and if any Cracks are found, scrap it. It's just not worth the risk.
The back of the Rack, where the Yoke runs also wears. Those that were assembled with Grease fare far worse in this dept than those that were filled with Oil
part 6  coming,,,,,,,,
#6 Spider
  • 15,198 posts
Posted 12 November 2016 - 06:55 AM
and the Bushed end
Inspect the Main Housing / Body
Down where the upper Pinion Bearing seat
the Yoke housing
check it for feel with the Yoke, if there's any noticeable side movement, check with a feel gauge, no more than 0.0015"
If it has more than 0.0015" play, then it can be safely assembled and used, however it won't have a nice tight feel about it.
Pinion Bearings. Usually these are good, I don't replace these as a matter of course, only if need be
They are hard to find these days. There's no UK supplier I am aware of who has them, however they are obtainable from a few Australian suppliers.
The Tie Rod Ball
and it's Seat - Check for Cracks and Splits
Check the Spring for Cracks
And the Tie Rod Nut Ball Seat
Shims
Yoke Cover - check that the Yoke hasn't hammered a divot in to it and that's it's flat
If some small wear is found on this cover, while it maybe tempting to turn the cover over, it may not seal too well as the Yoke side has a ground finish. The best bet here would be to have it ground flat again on a surface grinder.. I wouldn't recommend removing more than 0.010", though it's likely, if this plate has that much wear in it, the rest of the rack will be very knicked about and unlike to be savable in any case. I've only come across about 5 or 6 in all my years of doing these that needed touching up.
#7 Spider
  • 15,198 posts
Posted 12 November 2016 - 08:00 AM
Part 7
Same for the Pinion Bearing Cover (note the Gasket as mentioned earlier). These may also be re-ground as mentioned for the Yoke cover.
Bearing Shims
Yoke Spring - Check for Cracks
Now to start assembling if all checks out
Fit the Upper Pinion Bearing
then the Pinion itself - and the spacer - if fitted. Refer to the drawing a few down \/
the Lower Bearing
At this point we'd 'normally' check for Bearing Preload by meaning how far proud the Bearings are, but from my experience, I've found measuring it a little hit and miss due to the Bearings being an Angular Thrust type, so they tend to roll around rather than sit flat. The Factory state the Preload needs to be 0.001 to 0.003". I usually reassemble them as they came apart, with all the shims etc that were in and feel it. The Pionon should just and really do mean only just, be able to be turned with your fingers and while quite firm. it must be smooth all the way around.
Some Racks have a loose spacer on the top of the Pinion. This diagram may help get all the bits assembled in the right order. NOTE that not all racks have the spacer.
Adjust if need be, though you might need to be inventive if looking for Shims, One possible source might be those used on the crankshaft sprockets for the timing gear, however, these only come in 0.005".
Once you have the Pinion right, take it apart and set it to one side.
part 8 to follow
#8 Spider
  • 15,198 posts
Posted 12 November 2016 - 08:01 AM
Next up is to re-fit the Bush. You'll want to replace the Bush itself (sorry, I didn't on this one, so no pics, but there's not much to it)
Line up the hole for the retaining screw
Drive it in, don't go Ape as they don't need much force to go all the way home - Rolled Side of the Housing out!
Check the Holes
Then apply some sealant, my favorite for this job
a dab under the screw
then replace the screw
Note this screw is very short, about 4 - 5 mm. Don't try anything longer!
Insert the Inner Rack
turn it so the Teeth are in the right orientation
and Centralise it
part 9,,,,,,
#9 Spider
  • 15,198 posts
Posted 12 November 2016 - 08:20 AM
Then re-fit the Pinion
however if it has the single scallop for the Pinch Bolt, be sure to put it in with the correct Indexing
This is so that the Indicator Canceller ends up in the right place (not applicable to all models, though good practice all the same) and also so the Steering Lock indexes correctly
Re-fit the Bearing and Shims as before, then apply some Sealant to the Gasket
and fit the Bearing Cover back on using the 2 Shorter Bolts
Slowly move the Inner Rack over to one side, this should be done in while turning the Pinion
then fit the Yoke
and the O Ring (which is a BS212 sized O Ring)
Don't fit the Yoke Spring at this point
The Yoke should stand slightly proud of the Body. Check the how far proud and select a suitable Shim to Load the Yoke by 0.002 to 0.005".
Fit the Yoke Cover at this point with the selected Shim
Centralise the Rack and check for Play. The Play can be checked in a number of ways, however one of the best is to see if the Inner can be rotated to any degree. You'll be able to get some rotation out of it, and while not easy to put a number to it, if you can get more than about 0.020" 'rotation' at the circumference of the Inner Rack, then it really need to be tighter.
We shim at on the of the 'Turned' Steering Movements, as this is where the Rack will have the least wear, so we don't want it too tight here, or it might be embarrassing! After Shimming, we check how effective that has been in the Centraised position as this is where it will have the most wear.
It'll take a bit of tooing and foing to hopefully arrive at a happy medium, though, if there is a fair bit of wear, you might not be able to 'get there' by shimming alone. This is a non-standard practice, but I take a lick of a few thousands off the shaft around the Toothed end in the Lathe, certainly no more than 0.005". If you do this, you want to end up with a good surface finish, grinding would be best, but what you can get with a tipped tool I've found quite acceptable. Then refit, reshim.
The more time and care that's taken here, the better the car will 'feel' when it's all assembled.
Once you've got the Yoke Shimming sorted, take the Yoke Cover off again, and then fit the Spring
part 10 to follow - almost there!
#10 Spider
  • 15,198 posts
Posted 12 November 2016 - 08:46 AM
Next up is to fit the Tie Rods
Clamp up the rack Body as was done when disassembling and wind on the Locknut, wind it down out of the way
the Spring
Check the Seat has it's Washer - very important!
Fit the Seat
apply some Moly Grease to the Ball of the Tie Rod at this point. The Main Nut isn't slotted or grooved, so Oil isn't going to get in there too easy.
Then fit the Tie Rod with the Main Nut
Wind down the Nut, by hand preferably, while pushing down as indicated by the arrow every 1/2 a turn, keep winding just until all the play has gone, then wind on a further 1/8 turn.
Lock up the Main Nut with the Lock Nut
Do the same the other end
Fit the Pinion Seal. Wind some Tape over the shaft to avoid damaging the Seal
Fit the Seal over the Shaft
then drift the Seal in until it's just flush
however, note that as the Pinion isn't square to the Body, the Seal should be cocked off a little
Fit up the Boot to the Passenger's end. I like to apply some Sealant to the Body (only - not the the Tie Rod)
It's worth checking that the Screw on the Clip isn't going to dig in to the Boot on full lock
if it looks like it will, then I fit a longer screw to the clip and then a Dome Nut to the end of the Screw
TIP: Don't use Cable Ties for on the Boots or the Rack will leak for sure. The Original Clips are best, but if you haven't got them, look for Fuel Hose Clips, generally in the 11 - 14 mm range, not the usual Worm Drive types though, just those that look like these ^.  CBS have 'Flattie' Cable Ties that are quite suitable for the Big End.
Here's a clamp I did find new    http://minikingdomon...ose-boot-clamp/
I would recommend refilling the Rack with Oil. Up to about the late 1970's these Racks were Oil Filled and the Factory manuals still recommend this. The correct Oil is a 90 weight and it will need 200 ml. To fill them, I stand them up, with the Pinion end upper most and slowly tip the Oil in that end. It won't take it all in one go, so be warned, it will want to burb. Usually about 3 or 4 goes is less messy!
Then fit the Boot on the Drivers end.
That's it, easy :D
By doing them yourself, you can not only save money, but also end up with a superior Rack to a new one
The Bush are still available from most suppliers P/N 37H8064
Bearings, don't seem to be available in the UK, however we have a few local suppliers who have them, P/N BTA662   http://minikingdomon...nion-bearing/   though it's seldom these need replacing.
Pinion Seal P/N  17H6293
Boots P/N GRV205 (I would recommend the Unipart boxed ones)
Yoke O Ring  BS212
#11 sledgehammer
sledgehammer
  • 3,109 posts
Posted 12 November 2016 - 10:54 AM
This needs pinning it so everyone can find it easy
really good job Mokespider
can you show this to some 're-conditioners' over in the UK please - as most don't seem to know / bother to do any of this
over the years , I've had several racks , that were wiped down , new boots , quick spray , & they were magically 'reconditioned'
good to know some people know - or are bothered to do the job right
the annoying thing is , once you have done several , they aren't that hard to do
but I must confess - it's been years since I've had to do anything to one , so this guide is a great refresher
- I did spend a few seconds looking at 'marks' on the rack face , trying to fathom how it had worn like that - only to realise it was the moke grill water mark - DOH !!!
#12 Archived1
Archived1
  • Archived
  • 619 posts
Posted 12 November 2016 - 11:21 AM
This is awesome!
#13 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 12 November 2016 - 02:57 PM
Great guide, thank you for taking the time to put it all together
#14 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 12 November 2016 - 05:14 PM
Really great and informative guide Moke Spider!!! as above it would be nice to pin this. :proud:
#15 Steve8274
Steve8274
  • 580 posts
Posted 12 November 2016 - 07:56 PM
Thanks for the info
