Bmc 1100/1300 - Ado16 Honda Vtec Kit
2 replies to this topic
#1 mab01uk
mab01uk
  • 12,402 posts
Posted 13 August 2016 - 08:03 PM
Just noticed MiniTec in the USA do an ADO16 Honda Vtec kit....
Now Available:
The MTAA-B Series Kit was designed to install Honda’s B Series DOHC engines into the Austin America, Morris, MG, Riley, Vanden Plas, Wolseley, 1100's, and 1300's. , upgrading the Classic Austin America's A-Series engine with today’s most trusted engines built by Honda. We have taken all of the headaches out of this engine swap by developing the MTAA-B subframe. The MTAA-B subframe mounts directly to the America using the stock locations. This kit does NOT require any exterior body modifications. The MTAA-B Kit includes: MTAA-B subframe, adjustable suspension arms, Hybrid Chromoly Axle Shafts, Hardware, brackets, and instructions. All subframes are painted black. Because the AA uses hydrolastic suspension, a rear modification is required. We supply the necessary brackets for this modification with the kit and you can use our Coil-over shocks or something comparable.
Rear frame modifications: shock bars, shock tower pockets, c/o shocks, drill spindle to 1/2-20 for lower shock mount.
Order Kit No. MTB-AA
http://www.superfast....com/MTB-AA.htm
#2 A-Cell
A-Cell
  • 1,610 posts
Posted 13 August 2016 - 08:09 PM
Another good spot.
Sir Alec would turn in his grave! Not because of the engine but replacing the hydrolastic suspension.
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 13 August 2016 - 11:34 PM
they've been doing this for yonks.
have got a vdp that we are going to stick a meg 225 engine and box in when we get a bit of spare time.
