Spi Inline Fuses. Why Oh Why Rover?
11 replies to this topic
#1 brivinci
brivinci
  • 1,225 posts
Posted 14 July 2016 - 01:52 AM
If any of you own an SPi, at some point this might happen to you...as it did AGAIN to me recently. I was driving my 94 the other night and the dash lights went out. They came back on after a second or two and stayed on the rest of the journey. The next night, the never came on and then I notice a slew of other strange things. My fogs (now driving lights) would only work with the hi-beams and my switch illumination mod wasnt working. I set about tracing wires and ended up taking the entire dash out...all to find out that it was an inline fuse!!!
Maybe Rover cheaped out a bit when they sourced them? Maybe they should have just fitted blade fuses from the start? All I know is that these damn things have caused me more trouble then I care to remember. The trouble is that the fuse can become warm/hot and start to heat up the fuse holder. Over time, and many heat cycles the plastic get tired and starts the deform. Sometimes it molds around the fuse itself other times it pushes the non-sprung end into the recesses of the plastic. In either case, what can happen is the fuse loses contact with non-sprung end of the inline fuse holder and you have a dead line.
This is what happened to my dash lights. I have gone through and replaced a handful of the other inline fuse holders with similar (to keep it standard looking) type holders but of a better quality. Looks like i need to start replacing them all. This little problem has actually felt my car totally immobilized on two occasions when I first bought it. Well, hopefully never again!!
If you ever find a strange outage in power, dont only check the fuse but also that there is continuity when installed as well AND that the fuse and spring both move freely.
#2 ryomini
ryomini
  • 583 posts
Posted 14 July 2016 - 01:58 PM
brvinci
inline fuses can cause all sorts of problems
sometimes the fuse is not broken but the current doesn't flow, there is poor contact with one of the ends
they often cause problems in scooters as they tend to have a fuse near the battery
I have the same set up as you, I am thinking it would be a good little project to fab up or purchase a little fuse box and rewire in the
 same place
sometimes the holders just give up and the fuse drops out - but unfortunately that is not the only miserable design feature on the mini - haha
#3 brivinci
brivinci
  • 1,225 posts
Posted 14 July 2016 - 07:16 PM
No, sadly there are many:-)
Yeah, my brothers 95 has a neat little blade-fuse multi fuse holder, as standard I believe, mounted where the typical 4-fuse block is. I believe it does away with nearly all of the inline fuses. LOADS simpler to figure out what went wrong.
I thought about doing something similar but would need to source all the correct color wires and fuse panel to suit my overly anal ways in keeping certain things perfect
#4 ryomini
ryomini
  • 583 posts
Posted 15 July 2016 - 01:39 PM
Really
can you get a picture up
redoing all the fuses is something I would enjoy tackling later on once I am up and running again
the fuse box on the drivers side of the engine bay has a 2 tiered spade input - if there was a fuse box like that it would make
wiring up a cinch - plus I have a very good soldering iron
for the other side, the separate fuse holders - I have seen a six row fuse box for just a couple of quid so that is a big must on my 'to do' list
#5 brivinci
brivinci
  • 1,225 posts
Posted 15 July 2016 - 02:30 PM
That is very true about the original fuse holder having the blade terminals. Good point. Only thing is I'm sure there is not enough wire length to get everything where it needs to be.
I think if you were going to actually tackle this, it would be best to get rid of ALL inline fuses/glass fuses and replace with one single blade type fuse holder in a central location like what my brother has. Apparently, I asked all about this is a previous post and needed to re-read to jog my memory. The wiring diagram is exactly the same from 94-late 95 (some 95's being made in early 96 even) with the only difference being that the very late 95's had all the inline fuses replaced with a single, central 24 blade fuse holder. Now that I know that (again) I am going to be on the look out for a complete wiring loom from a 95 and plan on swapping it over in the future.
#6 FlyingScot
FlyingScot
  • 2,676 posts
Posted 16 July 2016 - 08:38 PM
Yes changed on later ones thankfully. On my early cars I replaced the inline glass fuses with waterproof blade holders which I bought from a chandlers.
FS
#7 Kam
Kam
    Straight to the Point
  • 4,144 posts
  • Local Club: 16vMini club
Posted 16 July 2016 - 10:11 PM
I got rid of my in-line fuses (1993) and swapped them (just them) for the blade type, got an appropriate blade fuse holder from - Vehicle Wiring Products
Before you go buying like for like rating blades the same as the glass ones your taking out have a read
http://www.theminifo...to-blade-fuses/
Hth
#8 brivinci
brivinci
  • 1,225 posts
Posted 17 July 2016 - 01:12 AM
If a miracle happen and I find a mint, later 95 SPi wiring setup, with the 24-fuse panel, then I would set about changing it. Otherwise, I'll stick with the inlines and just upgrade them where I can. My brothers 95 setup is serious sooooo much better. So simple. What took them so long:-)
#9 ryomini
ryomini
  • 583 posts
Posted 19 July 2016 - 01:46 PM
Kam
like what you did that's neat and tidy and not too much work either
#10 FAZ
FAZ
  • 284 posts
Posted 19 July 2016 - 06:39 PM
i replaced all mine with blades,
#11 ryomini
ryomini
  • 583 posts
Posted 20 July 2016 - 08:55 AM
Faz where are your leaks ? So clean
Your vacuum hose looks like it needs upgrading
the silicone hoses are trick
#12 FAZ
FAZ
  • 284 posts
Posted 20 July 2016 - 12:29 PM
Vacuum hose turned up in the post this morning.
Leaks? Nothing engine cleaner a rag and am old toothbrush can't fix
