Mx5 Powered Classic Mini
21 replies to this topic
#1 hazzar1236
hazzar1236
  • 14 posts
Posted 07 July 2016 - 05:35 PM
This was somewhere else in the forum but thought i should move it to the correct place
Here is my project, mazda mx5 mk1 engine powered mini 1000 (1.6 litre dohc engine ,roughly 110 bhp at the rear wheels, and an lsd, hopefully just under 700kg )
bought this about a year ago, truing to get it though an mot, but has to much rust, thought i got it all, so as i would have to fix that thought i ought to change it up just a little bit more,
post-105562-0-03990700-1467114105_thumb.
Then bought a classic mini shell, bit of rust on that too !! love that shame of these car so no panel changes at all.
post-105562-0-44696900-1467114068_thumb.
post-105562-0-02795700-1467114129_thumb.
next started to strip down the mx5
sadly all the photos of this are too big to be uploaded  :(
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 07 July 2016 - 09:14 PM
Upload them to photo bucket and copy the IMG codes to your posts
#3 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 12 July 2016 - 06:39 AM
These may be of interest if you haven't already seen them
Spaceframe RWD track mini
MX5 Estate
Neither of these have kept very much of the mini except the body shell.
If you wanted to keep the suspension and basic structure I imagine using one of the fwd gearboxes that attaches to the same motor.
It'll be interesting to see what you have in mind...
#4 hazzar1236
hazzar1236
  • 14 posts
Posted 15 July 2016 - 08:46 PM
Thanks had seen diggers project, and enjoyed reading the space frame one, i have in mind using as the stock mazda parts so having it rear wheel drive, almost exactually as diggers has done his :)
onwards with stripping it down then, nearly all gone
dash board part all cut out
Attached File  IMG_0258.JPG   69.35K   24 downloads
then the front part cut down
Attached File  IMG_0263.JPG   85.09K   26 downloads
cut the sill and rear quarter, and the other one is done as well
Attached File  IMG_0265.JPG   67.61K   19 downloads
and then cutting up the back bit just got to do the other side of it
Attached File  IMG_0266.JPG   65.43K   19 downloads
#5 hazzar1236
hazzar1236
  • 14 posts
Posted 24 July 2016 - 06:00 PM
Heres an update,
after going though 10 angle grinding discs and 8 reciprocating blades, finally nearly all done with the cutting up, just the A pillar section left and a bit of the dash left
Attached File  IMG_0273.JPG   72.08K   16 downloads
Attached File  IMG_0272.JPG   80.3K   13 downloads
Then moving on to the rear section, which makes quite a big difference,
Attached File  IMG_0264.JPG   63.56K   14 downloads
Attached File  IMG_0270.JPG   72.2K   8 downloads
Now thats all cut out, i did a bit more work on the front,
Attached File  IMG_0263.JPG   85.09K   15 downloads
Then a few extra photos, parts pilled up on the mini and another rear section one :)
Attached File  IMG_0267.JPG   72.33K   24 downloads
Attached File  IMG_0271.JPG   60.83K   10 downloads
#6 hazzar1236
hazzar1236
  • 14 posts
Posted 19 September 2016 - 02:45 PM
Have got a bit further now,
the A - pillar section are now done
Attached File  IMG_0275.JPG   81.15K   17 downloads
Attached File  IMG_0284.JPG   86.64K   14 downloads
The front has also been cut off
Attached File  IMG_0309.JPG   71.18K   13 downloads
more to upload !!!
#7 hazzar1236
hazzar1236
  • 14 posts
Posted 19 September 2016 - 03:04 PM
just a little tool made from one of the boot hinges and 2 bolts,
Attached File  IMG_0280.JPG   62.59K   6 downloads
Attached File  IMG_0282.JPG   68.02K   11 downloads
now the scary part, cutting it in half !!!
which ended up like this ......
Attached File  IMG_0294.JPG   33.01K   25 downloads
after shortening the wheels base by 25 cm and alining it, it now looks like this
Attached File  IMG_0300.JPG   72.09K   54 downloads
Attached File  IMG_0302.JPG   67.96K   30 downloads
just need to cut the floor out with mini then place it on top, then more alining, then some welding :)
#8 bluemini17
bluemini17
  • 158 posts
Posted 31 October 2016 - 02:51 PM
This is going to be a weapon. I have both cars, and they are equally fun to drive. Are you going to turbo the mx in the future. Maybe too much power
#9 hazzar1236
hazzar1236
  • 14 posts
Posted 31 October 2016 - 06:15 PM
I am sure it will be a weapon !!!!! can't wait to drive it :)
But for now more cutting and cutting ............
Attached File  IMG_0327.JPG   61.73K   15 downloads
Attached File  IMG_0326.JPG   58K   13 downloads
now it looks kinda like a car !!!
Attached File  IMG_0348.JPG   66.96K   53 downloads
Attached File  IMG_0331.JPG   68.66K   30 downloads
then came the wheels, they are corsa b model 13 inch wheels (et46)
Attached File  IMG_0372.JPG   62.33K   16 downloads
Attached File  IMG_0370.JPG   69.86K   11 downloads
#10 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 01 November 2016 - 12:27 PM
this looks cracking!
#11 hazzar1236
hazzar1236
  • 14 posts
Posted 18 January 2017 - 01:07 PM
well a bit more progress has been made;
Attached File  16128524_756527721189833_1736432781_n.jpg   47.93K   95 downloads
mainly I have been welding up the sills and the floor so not to much to see there but will up load those photos at a later date
#12 Mannheimer
Mannheimer
    Starting My Mini Up
  • 1 posts
Posted 26 January 2017 - 05:20 PM
Very nice! I wanted to do such project myself. Looking forward for more pics.
#13 hazzar1236
hazzar1236
  • 14 posts
Posted 28 January 2017 - 04:41 PM
here are the more photos
front antiroll bar brackets are now finished
Attached File  16409468_762370473938891_540813893_o.jpg   62.43K   28 downloads
and some progress on the floor
Attached File  16389246_762370483938890_1721020814_o.jpg   32.99K   23 downloads
Attached File  16326907_762370543938884_1932744312_o.jpg   24.74K   21 downloads
and some more on the sills
Attached File  16409187_762370523938886_2051438892_o.jpg   31.33K   27 downloads
Attached File  16409354_762370510605554_1184724865_o.jpg   42.09K   21 downloads
Attached File  16388721_762370547272217_688514362_o.jpg   36.14K   30 downloads
#14 hazzar1236
hazzar1236
  • 14 posts
Posted 27 February 2017 - 06:00 PM
Radatior is now in placed and pumbled up :)
Engine starts and runs !!!!!
will link a video in the next update (over the weekend) of the engine running and a walk around the car is its current state.
#15 hazzar1236
hazzar1236
  • 14 posts
Posted 17 April 2017 - 08:59 PM
Here is a mid-build video update ---
