1967 Australian Morris Mini Deluxe Wiring Diagram?
4 replies to this topic
#1 Darthteddy
Darthteddy
  • 21 posts
Posted 26 August 2015 - 02:58 AM
I am trying to find out which wiring diagram is the proper one to use for my 1967 Morris Mini Deluxe. Ive searched around, but not had much luck with anything conclusive. I attempted to work off of the "Cooper, Cooper S, Countryman, traveller, and super deluxe 64-67, hover there are quite a few anomalies. One of the biggest being that there seems to be some sort of "Control Box" that wires are going into and coming out of on the diagram, which I do not have. It looks like a previous owner installed an aftermarket harness, and there are quite a few loose ends. Any help locating the correct diagram would be fantastic.
Thank you.
My car is an Australian spec, fitted with the 998 engine, alternator, negative to earth battery set up, no heater, and a 3 gauge center binnacle.
#2 Spider
  • 14,789 posts
Posted 26 August 2015 - 03:51 AM
This will be it;-
Aust%20Deluxe%20Wire%20Code_zpsupzce9gr.
However the 3 gauge centre cluster was never factory fitted to that model (MIni K they were), but electrically, there's not much in them.
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 26 August 2015 - 05:52 AM
...and your car has been modified by updating it to an alternator in lieu of the original Dynamo. So wiring will have been modified to cater for that.
#4 Darthteddy
Darthteddy
  • 21 posts
Posted 26 August 2015 - 09:17 PM
Cheers guys thanks. Even on ausmini I was having trouble finding one.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 August 2015 - 11:01 PM
The box you refer to would have been the dynamo control box, as A-Cell pointed out its been modified to a alternator
