4Wd Gearbox Conversion
74 replies to this topic
#1 Spider
  • 14,783 posts
Posted 10 December 2014 - 08:51 AM
Well, I should kick off by say this is not for me! This is actually the repair of a Gearbox for a Moke known as Quadra. suffered a major failure at an outing a few years back now. I undertook this re-design / repair back in early 2012.
It was originally made by a guy in our club, Max Kinsmore, back in the late 70's. The Bevel Gears used in this one are actually from a Prototype that was Made by our local Leyland Factory as they were considering putting these in to production - another story for another time!   I digress - This Leyland Prototype design is actually based upon the Leyland ST Mini, which in turn was based on one of Issigonis's Prototype Single Engine, 4WD Mokes of the early 60's.
A Friend of mine now owns the Moke, which is not a factory car, but does have a few factory parts in it.
This was the gearcase from it, after I'd stripped most of it
When it was stripped down, the diff pinion was found in a hundred pieces. Not the first one I've seen like this
but closer inspection of the gearcase show a LOT of other problems, most of them old, but signs that this design was not up to the task
the case and the diff cap were fund FULL of cracks and other damage from previous failures. The diff cap hardly even lined up, so no wonder it leaked oil.
It was off to the drawing board for a few weeks. I came up with a solution and design to overcome all it problems and (hopefully!) make it un-breakable.
So, next thing was to start making all the bits
First was the diff hemispehere. The stock 2 sun gear designs are hopeless, so I made a 4 sun gear, X-pin type
I had to make a special tool to cut the thrust faces for the sun gears
trial fit to check it's shape - perfect!
now to cut them for real
starting to take shape
next, I had to machine up a crown wheel, this is another weak point in the stock mokes and this one is no exception
then fit the bevel gear to it
then the next major problem part, the diff cap. We got a new gearcase and I had to measure up super-accurately the existing diff cap
I machined up a new one from a soild billet. Here, I'm just starting to face it, to get it 100% square and flat
then next was the bearing tunnel. to get this perfectly round and on size, I had to bolt it up to another piece the same. This is the start of something BIG
back in the lathe
boring it
perfect!
pitch out and drill all the holes. This needed to be super-accurate (I was working to +/- 0.005 mm!)
fits and lines up! Bonus!
next, some relieving of the gearcase as the new diff is bigger
trail fitting the diff
yippie!
next, I had to measure exatly where the output pinion needed to be for the RWD part
then, I could machine out the guts of the cap
look it fits!
then face back the cap to get it all lined up with the gearcase
planing the back of the diff cap at an angle, to get the output pinion facing the right way
boring the hole for the pinion
just about there!
there, all major machining done!
all that's left now is the big clean up and assembly!
To be continued.
#2 Spider
  • 14,783 posts
Posted 10 December 2014 - 08:54 AM
Here's some pics of the original proto-type Crownwheel
There's the part number. Anyone got a reference to it?
You can see that this one is missing teeth, but also, that it has the bearing mount. Oddly, there are only 3 bolt holes for the hemisphere, I have no idea what the score was on that.
The ratio of the bevel gearset is 2.1:1 so way too tall to be a diff from any other vehicle that I know of. I am in no doubt that these are genuine Moke ones.
On the Left is the new Crownwheel and the one that was fitted on the right (I have machined the bevel gear out of it). I think the new one will be considerably stronger!
And the new Pinion too (on the left).
Some pics of the diff cap that was on it
This was a Remote Shift cap on a Rod Shift Box!!!!  I doubt that this was done by the factory, I think this was some of Max's handywork. The alignment was unbelievably poor. I have no idea how it held oil. You can see some cracks and gouges from previous learning experiences.
I did look long and hard at welding a flange to the back of the shock Rod Shift Cap, but there is next to no meat in it. All the stock one really has to do is keep oil in, this one does a little more  wink.gif
This is the Factory proto-type hemisphere
You can see the chatter marks from the bevel gear teeth! This was because the whole assembly was parting company (from the stripping threads) and effectively bending. I have a black and white pic of the factory units I'll throw up a little latter (when I dig it out!).
Edited by Moke Spider, 10 December 2014 - 08:57 AM.
#3 Spider
  • 14,783 posts
Posted 10 December 2014 - 08:56 AM
Some progress
The Gear Shifter set up had something missing! It had no steady on it and so when accellerating or decellerating it was prone to jumping out of gear
So, I had to nut out a steady. Not having the car here made it had to make decisions as I didn't know what was where and what clearances I'd have.
So I brazed a bracket to the output pinion bearing carrier
Then bent up a suitable rod
I've also made up some spacers and so now ALL machining and fabrication is done!
Yipppeeee - it felt like a marathon!
So this afternoon, I tubbed everything up
Edited by Moke Spider, 10 December 2014 - 09:17 AM.
#4 Spider
  • 14,783 posts
Posted 10 December 2014 - 09:00 AM
Really taking some shape here
Hopefully I'll have it fully assembled today. I've also now got the front Subframe here, so I can trial fit it and check that it actually fits - that could be embarrassing!
Here's a couple of shots of the subframe
The spacers on top measure a total of 31 mm. I'm not entirely sure why these are needed, but it maybe to get enough room between the tunnel in the floor pan and the output rear facing drive. The pics of have of the factory ones didn't seem to need any spacing. I might get a better idea later today when I trail fit them together.
Tada - it's FINISHED  grin.gif (much to my good wife's relief)
#5 Spider
  • 14,783 posts
Posted 10 December 2014 - 09:03 AM
Following this repair / rebuild, the owner of the car in to which it belongs undertook a full restoration of the whole car, it's now been on the road for about a year now, he's commented that for the first time in his ownership it doesn't leak oil (funny about that!) and it's surprisingly so much quieter than it's ever been, all he hears now are the tyres and some exhaust note!
#6 steve m
steve m
  • 78 posts
Posted 10 December 2014 - 09:10 AM
Can,t see any pictures
#7 Spider
  • 14,783 posts
Posted 10 December 2014 - 09:24 AM
Hmm,,,,, they are on photobucket, sometimes they are slow to load, just give it a few moments, if they don't pop up, I'll re-insert the images.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 10 December 2014 - 09:25 AM
Phenomenal work.
#9 Carlos W
Carlos W
  • 10,114 posts
I couldn't see them at first, but can now
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 December 2014 - 09:27 AM
Fantastic !
#11 cal844
cal844
  • 9,619 posts
  • Local Club: TFMOC
Posted 10 December 2014 - 09:55 AM
Epic and expensive work!!
#12 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 10 December 2014 - 09:58 AM
Unbelievable... You didn't make two did you? 😜
#13 brownspeed
brownspeed
  • 451 posts
Posted 10 December 2014 - 10:13 AM
Bloody Hell! I bet that was a busy couple of days!! ;D
love that workshop facility
#14 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 10 December 2014 - 11:45 AM
Fantastic work, I've dreamt about this sorta thing for mine for a while now. Would make the low traction situations I regularly find myself in a lot easier to maneuver out of...! If you'd ever be interested in making another id be seriously interested.
#15 coopdog
coopdog
  • 4,506 posts
Posted 10 December 2014 - 12:19 PM
That is amazing work
Never better than making something from scratch and watching it take shape!
