Refusing To Tick Over? Just Cuts Out.
12 replies to this topic
#1 Mrstars11
Mrstars11
  • 192 posts
Posted 06 November 2014 - 08:26 PM
Hi all,
Does anyone have any ideas as to why my engine won't tick over?
I first thought maybe it was due to getting colder, if that would make a difference at all.
But I went to work in it today to take it out for a drive, and I did about 8 miles, so it was nice and warm, got to a massive set of traffic lights, handbrake on, in neutral, and the engine ticked over for a couple of minutes then cut out, it started to struggle and died.
Like it was being choked almost.
If I keep some revs on its fine, but it means whenever im stopped I have to press the accelerator, otherwise the engine just cuts out.
Does anyone have any ideas?
I'm taking the block out next week for a subframe change so then would be a good time to sort it.
Thanks in advance.
#2 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 06 November 2014 - 08:35 PM
injection or carb?
#3 Mrstars11
Mrstars11
  • 192 posts
Posted 06 November 2014 - 10:41 PM
Its a carb,
1988 austin mini Mayfair, 998 stage 1 kit.
#4 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 06 November 2014 - 11:40 PM
Was the stage 1 put in recently? or have you done anything recent to it?
When was it last serviced?
Was it running fine up until that point?
Anything easily noticeable in the engine bay? Loose vacuum pipe etc
#5 Mrstars11
Mrstars11
  • 192 posts
Posted 07 November 2014 - 10:27 AM
stage one was fitted when i bought it.
serviced last june
was ticking over before ok yeah.
cant see anything, i was thinking maybe fuel pump? but i will check vacuum pipes too.
#6 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 07 November 2014 - 10:32 AM
Have you adjusted the tick over screw on the carb?
Mine did the same, done a twist on the screw and adjusted the tick over revs.
You can have it low and splutter or wide open, personal choice :)
#7 Mrstars11
Mrstars11
  • 192 posts
Posted 07 November 2014 - 12:29 PM
hmmm, i remember i twisted a bolt on the underside of the carb i thought it was to stop it running so rich?
because my spark plugs were getting very black and soot covered, so i turned it to try and prevent that. I thought thats what it did anyway, but it could be that ive just made it not tick over?
thanks matt050990
#8 Mrstars11
Mrstars11
  • 192 posts
Posted 07 November 2014 - 12:30 PM
is it the screw under the carb? i adjusted that as just mentioned...
#9 matt050990
matt050990
  • 1,199 posts
Posted 07 November 2014 - 12:49 PM
What type carb have you got mate?
Let my know the style and ill see if it can find a pic....
#10 matt050990
matt050990
  • 1,199 posts
Posted 07 November 2014 - 12:51 PM
This is a HS4 carb, same as mine
#11 Mrstars11
Mrstars11
  • 192 posts
Posted 07 November 2014 - 01:37 PM
that looks about right mate yeah, im pretty sure its a hs4.
#12 Mrstars11
Mrstars11
  • 192 posts
Posted 07 November 2014 - 01:45 PM
its an inch and half hs4 standard carb
#13 matt050990
matt050990
  • 1,199 posts
Posted 07 November 2014 - 02:26 PM
Same as mine then mate.
If you adjust 2 & 3 screws you should be able to fix the idle revs mate.
