I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#661 nicklouse
  • 18,591 posts
Posted 29 February 2020 - 12:21 PM
So what went into a 9k able engine back in the mid 90s
And the head
Thickness is 2.63”
It's surprising what tweaked factory components can withstand.
Looks very similar to my early 90's built MED engine with Longman head, except I'd had the crank wedged and only had forged minispares 1.5 rockers.
yep at the time all the I and H beam rods were very expensive and the crank tec had hardly moved on from wedging and Billit made.
this one was basically a re built Holwey base unit and head.
#662 imack
imack
  • 2,110 posts
Posted 29 February 2020 - 12:32 PM
Howley, now there's a blast from the past!
#663 nicklouse
  • 18,591 posts
Posted 29 February 2020 - 12:35 PM
and their turbo Metros.
#664 nicklouse
  • 18,591 posts
Posted 29 February 2020 - 09:38 PM
a mix of head studs used.
#665 nicklouse
  • 18,591 posts
Posted 29 February 2020 - 09:41 PM
when needs must
stay still
so far so good.
mmmm not really suitable for the Mini needed modification
but they did come out.
#666 imack
imack
  • 2,110 posts
Posted 01 March 2020 - 08:14 AM
Are you building the dog gearset into the remote box?
#667 nicklouse
  • 18,591 posts
Posted 01 March 2020 - 11:17 AM
Yep.
#668 imack
imack
  • 2,110 posts
Posted 01 March 2020 - 11:33 AM
Yep.
I presume the MED pinion support housing needs modifying to clear the internal shift linkage.
I had to grind a web back on my KAD housing for clearance on my remote box.
Edited by imack, 01 March 2020 - 11:34 AM.
#669 nicklouse
  • 18,591 posts
Posted 01 March 2020 - 11:44 AM
Yep.
nothing was mentioned when i collected it all. and i did just throw it in place to see but i can remember what stage of strip down i was at then but nothing seemed to be in the way.
we will find out later.
#670 imack
imack
  • 2,110 posts
Posted 01 March 2020 - 12:14 PM
Yep.
I had to create clearance for the change speed gate (lobster claw) and the shift shaft. Decided to remove material from the shaft rather than the housing around the bearing. Think MED's webs are in different positions so they may clear.
I went for KAD as mines a road car and I wanted to retain the speedo drive.
#671 nicklouse
  • 18,591 posts
Posted 01 March 2020 - 12:18 PM
yep quite a bit different.
#672 nicklouse
  • 18,591 posts
Posted 01 March 2020 - 05:30 PM
did quick check before taking out the rest of the gears but without a gasket to make it worse.
no issues
everything out except for the reverse plunger on the front face.
any ideas?
#673 imack
imack
  • 2,110 posts
Posted 01 March 2020 - 05:51 PM
If you mean the reverse detent plunger, I think I pulled mine out with a magnet on a stick.
Good news that the pinion support fits without modification.
#674 nicklouse
  • 18,591 posts
Posted 01 March 2020 - 09:07 PM
thats what i am hoping unfortunately two are two big and one is too small and not strong enough.
#675 imack
imack
  • 2,110 posts
Posted 01 March 2020 - 09:17 PM
Have you sprayed brake cleaner or similar in there to try and dilute the oil before using a magnet?
May be worth trying to blast it out with compressed air.
