Hi all.
Having trouble wiring a smiths temperature gauge. So far what I have done is:
- run a wire from the sender in the head to the gauge and connected it to the LH plug. (The side with only 1 plug)
- Fitted a voltage regulator (TS7810CZ 1A Positive Fixed Voltage Regulator TO220 Case) from Maplin. The input side of the regulator went to a switched 12V supply on the fuse box. The centre leg to Earth and the output leg to the Gauge (RH side that has the 2 plugs)
- The above is measuring 10.1 V on the meter at the gauge and it is stable so the regulator is working fine.
- Any idea what the other plug should read from the sender in the head??
Not sure why it is not reading any temperature at all. Unless the gauge is broken but I don't think so.
Can anyone tell me if I have the plugs the wrong way round or what else may be stopping it showing any sort of reading. The sender is brand new.
Car is a 1275gt 1981 fitted with a 1300 metro engine.
photo 1 (6).JPG 69.15K
46 downloads
photo 2 (6).JPG 70.39K
68 downloads
