Where's My Engine Oil Drain Plug
19 replies to this topic
#1 Cambelt
Cambelt
  • 158 posts
Posted 23 April 2014 - 04:16 PM
So I'm giving my mini a little treat with new oil new filter and new spark plugs can any of you tell me where the drainage plug is ?
#2 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 23 April 2014 - 04:18 PM
It's on the drivers side of the sump
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 23 April 2014 - 04:19 PM
It's quite a big one compared to a lot of cars.
#4 big-jay
big-jay
  • 518 posts
Posted 23 April 2014 - 04:20 PM
If you look underneath the engine, on the drivers side, you'll see a small bolt head on the sump. That's the drain plug :-)
Edited by big-jay, 23 April 2014 - 04:21 PM.
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 23 April 2014 - 04:24 PM
In the picture linked below (not mine, borrowed from the net) the drain plug is the large hex-head shown horizontal on the front corner of the gearbox.
#6 Cambelt
Cambelt
  • 158 posts
Posted 23 April 2014 - 04:27 PM
Right oh thanks gents best find the jack and stand a looks like a tight squeeze haha
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 April 2014 - 05:05 PM
Be Careful they strip easy when worn
#8 Cambelt
Cambelt
  • 158 posts
Posted 24 April 2014 - 08:27 PM
Anybody know the size ratchet head I will need make sure I have it or will and adjustable fit in there ?
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 April 2014 - 08:35 PM
A couple of pitfalls to be aware of... You will most likely need a new copper washer and be carefully not to over tighten the when refitting the sump plug.
#10 lawrie124
lawrie124
  • 1,710 posts
Posted 24 April 2014 - 08:36 PM
Probably 24mm
#11 Cambelt
Cambelt
  • 158 posts
Posted 24 April 2014 - 08:49 PM
Was look on a site that sells the head they say it is 15/16
#12 Carlos W
Carlos W
  • 10,114 posts
Posted 24 April 2014 - 08:51 PM
It will be imperial.
#13 Alex_B
Alex_B
  • 4,573 posts
Posted 24 April 2014 - 08:55 PM
its imperial 15/16th
dont use a metric near equivalent as if you round it then it may cause issues!
#14 Dusky
Dusky
  • 5,322 posts
Posted 24 April 2014 - 09:28 PM
Also undo it slowly.. Or spill all the oil over your body like I did (a)
#15 Alex_B
Alex_B
  • 4,573 posts
Posted 24 April 2014 - 09:30 PM
And dont drop it in the oil pan because fishing in hot oil isnt fun!
