Might want to sit down, this is going to be a long one (that's what he said) oops.
But yeh, I'm not good with words, I ramble on a lot, I'll try and keep it brief.
Basics..
1992 Mini City 998cc Manual
The car has been sat for almost a year now undercover at my fathers work. He started it once a week or so, and I think he might of drove it a few times. But for a good few months now, I went to drive it, and the clutch pedal was completely solid, imagine a clutch pedal on Viagra.. there was no getting it down at all.
I tried levering the clutch arm on the assembly, nothing.. I then took the slave cylinder off, which was a complete pain in the ass for me, couldn't get a socket on anywhere, no ratchet spanners, so I was stuck moving a spanner about 1mm at a time. But yeh, I got that off, didn't really know what I was doing, I pushed something on the cylinder which made a funny squelch noise which made me laugh, and then I put it back on...
I thought I'd have a go at bleeding it, not sure why, but seemed like a logical idea for some reason, undid the nipple, and the pedal went straight down, I got excited, almost did a little love wee, but like most things... it was short lived and I pumped it through a bit, and when the nipple was done up, the pedal is now solid again.
All I noticed is that the thing that I've crudely marked out on Microsoft Paint, on someone elses photo
Is that the arm on mine does not move up freely, it moves about a centimeter at most, and is also not in that position, mine appears to be much lower down. but it's solid, it won't move up.
I pushed it into gear, and in all gears, I can still move the car by hand backwards and forwards, so I'm guessing the clutch is stuck on.
Also, just to confuse you more, when the engine was running, I pushed it into reverse, again, no using the clutch pedal, and the engine stalled?
Not a vicious stall at all, the engine literally cut out, and had trouble starting it for a few minutes.
Any help will be massively appreciated
