Oil Pressure Switch For Electric Fuel Pump
9 replies to this topic
#1 chrisp22001
chrisp22001
    Starting My Mini Up
  • 2 posts
Posted 05 May 2013 - 05:03 AM
Hi, Please could someone advise.
I have fitted a stage one kit and have had to remove the original mechanical fuel pump, as the outlet rubs against the exhaust manifold down pipe.
I have now fitted an electric facet pump.
I now need to fit the oil pressure switch somewhere in the system. Please could someone tell me where and how to fit the switch into the system.
Thanks, Chris.
#2 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 05 May 2013 - 05:41 AM
Hi Chris, have you actually got the switch already?
The purpose is to provide a safety barrier in case of an accident or such. Most people find a better option is to fit a re-settable inertia switch instead. (as fitted to factory injection minis)
http://www.ebay.co.u...=item589f6971f8
The oil pressure version kills the power when the engine stops, the inertia one when it receives an impact or jolt. In the event of an accident, if the engine continues to run, then the pump will still keep feeding fuel, whereas the inertial one should trip. Another issue is that when starting the engine, you are reliant on the fuel in the float bowl until oil pressure is generated.
Regardless of type, from a wiring point of view, they need to be fitted "in line" on the power feed to the pump. That is, from a ignition controlled 12v feed, via a fuse, through the cut off switch and then on to the pump. If using the oil pressure type, then you may need a "T" piece to go in where the sender for the oil warning light is situated. If you have a gauge as well, you may already have a "T" in place which may hamper the ability to fit the cut off.
The pump will work fine without either, but for safety's sake, fit one.
Hope this helps
Regards
Steve
#3 minirage
minirage
  • 165 posts
Posted 05 May 2013 - 06:28 AM
wired mine in yesterday, threw instructions in bin and wired to igniton switch live and just put a inline fuse in
#4 chrisp22001
chrisp22001
    Starting My Mini Up
  • 2 posts
Posted 05 May 2013 - 03:40 PM
Hi Steve, Yes I have the oil pressure switch. It has 3 connections for the wiring, but the thread is too big for the existing hole in the block. The wiring side is complete. I just don't know how or where to fit the oil pressure switch or what connectors I need.
The mini is a 1984 998 mayfair. Any advice would be welcome (before I take the stage one kit off and fit a standard exhaust).
Thanks, Chris.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 May 2013 - 05:07 PM
  It is EXTREMELY bad to have an electric fuel pump without some sort of crash cutout.  A friend of a friend was unfortunate enough to crash a car once while he lived in California.  He regained consciousness to the unforgettable experience of a jet of burning fuel from the fuel pump working like a cutting torch and slicing clean through his leg extremely slowly while he was trapped.  You MUST fit some sort of automatic crash cutoff that doesn't rely on you being awake or able to turn the key to isolate the pump.  I cannot stress highly enough how important this is.  Instructions exist for a reason.
#6 minirage
minirage
  • 165 posts
Posted 05 May 2013 - 07:03 PM
we live in England where fuel is well over priced sooooooo if I crashed the only thing being suckd by pump is fumes
#7 colinu
colinu
  • 523 posts
  • Local Club: MOASF
Posted 05 May 2013 - 08:57 PM
I went belt and braces and fitted both an inertia switch and wired in a PS-64 oil pressure switch too. There a very good page on how to fit the oil pressure here... http://www.how-to-bu...-fuel-pump.html
#8 Cooperman
  • 23,564 posts
Posted 06 May 2013 - 11:12 AM
Inertia switches are a new idea really. The Minis with electric pumps didn't have these and I always disconnect them as I've had them 'trip' when driving along a rough road. If the idea of a fuel pump continuing to run after a crash, then fit a battery cut-out switch which kills all the electrics.
Edited by Cooperman, 06 May 2013 - 11:13 AM.
#9 java gt
java gt
  • Just Joined
  • 120 posts
  • Local Club: Irish Mini Owners Club
Posted 06 May 2013 - 03:19 PM
Darwins theory should take cars of this :shifty:
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 September 2013 - 09:06 PM
Or a Competition 3 terminal Oil Pressure Switch designed to work the Facet Pump
