Front Bearings Worn
Posted 20 February 2013 - 05:47 PM
Any ideas out their
Posted 20 February 2013 - 06:00 PM
Posted 20 February 2013 - 07:28 PM
Posted 21 February 2013 - 08:55 AM
Is there wear to the tapered/thrust washer?
I think Algordo1100 was making reference to the top and bottom ball joints of the front hub carrier/upright..is there any play in these?
In case you haven't got a manual here's the diagram of the front hub assembly:
Edited by cptkirk, 21 February 2013 - 08:57 AM.
Posted 21 February 2013 - 10:05 AM
No. 15 thrust weasher is the common suspect here we have them on stock as do many other mini specialistJoss, Are you losing the brake pedal? as in if you drive it a bit do you need to pump the pedal to brake?
Posted 22 February 2013 - 06:50 PM
Posted 25 February 2013 - 11:54 AM
Thank you for the diagram I have installed the new thrust washer but when I dismantled the bearings the oil seal spacer was not installed could this have been the demise of my front bearings?
Joss, the lack of spacer might well explain the need for you to add the washer the first time.
Posted 25 February 2013 - 03:38 PM
Did you tighten the assembly with a flat washer in place of the conical washer first to pull everything together? If not the conical washer could have clamped down early and left you with this play despite the castle nut being torqued up.
Posted 25 February 2013 - 06:17 PM
have you fitted the rubber inserts to the front and rear scree rubbers yet? if not i would make it a priority as the screens don't take much to pop out :-0
Ed
Posted 25 February 2013 - 07:09 PM
The spacer you speak of, do you mean the one that goes between the two inner races of the bearing?
If this is missing and the OP has tightened the castle nut to the specified torque the bearing is most likely scrap is it not?
Posted 25 February 2013 - 10:10 PM
Yes I mean the spacer between the 2 races. I think when the previous owner swapped the bearings he had not fitted the spacer. So recommended that he buy new bearings along with the spacer and wedge shaped washer, and torque to the manufacturers spec. whether or not he done this I'm not sure.
Ed
Posted 26 February 2013 - 06:02 PM
Posted 27 February 2013 - 09:29 AM
Item 5 is the oil seal spacer it seems to be common that they get thrown out as they're not strictly needed. I put mine back in though just makes everything a much neater job in my opinion.
Glad you've got it all sorted.
Posted 11 March 2013 - 06:44 PM
Posted 30 March 2013 - 10:47 AM
I got a new set of bearings and a new tapered washer but when i dismantled the original bearings it was missing item 5 in the layout diagram I managed to get one and all went together swimmingly and works well (apart from that bloody grease). Thanks for the advice guys.
Joss where did you get your spacer, I am struggling to find one on the normal site like minispares & minisport??
