Jonspeed Review
28 replies to this topic
#1 holmesy
holmesy
  • 879 posts
Posted 19 December 2012 - 08:25 PM
has anyone here know of any good and bad reviews of them as my father wishing for me to buy a stage 2 engine from them instead of doing my own but as cooperman has said to me 1500 just seems too cheap.
http://www.jonspeedr...=14523&cID=2095
this is the head which comes with the engine which is 500 from them on its own!
http://www.jonspeedr...=14480&cID=2090
too good to be true????
#2 bully
bully
  • 51 posts
Posted 19 December 2012 - 08:32 PM
if i was you i would steer clear from jonspeed! (from personal experience). there are plenty of good engine builders out there just depends on what budget you got and what you want in the end.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 19 December 2012 - 08:35 PM
If you make a statement like that can you give your reasons why please.
#4 holmesy
holmesy
  • 879 posts
Posted 19 December 2012 - 08:48 PM
where would be the best place for a full engine or kit, have looked at the med kits and will be enquiring further but want to limit myself to 1500 for a kit, i have things like duplex timing gear, kent cam and a fairly good head from my current engine. and please state your reviews as will help me decide and i wont tell :whistling:
#5 holmesy
holmesy
  • 879 posts
Posted 19 December 2012 - 08:49 PM
Name some builders ta!
I spoke to Tony at Jonspeed seemed to know what he was on about .
#6 bully
bully
  • 51 posts
Posted 19 December 2012 - 08:53 PM
basically i brought a crank which was x drilled knife edged wedge and ni tempered which got fitted to my race engine in the second heat at racing i was still running the engine in when suddenly the engine went bang! what had happened was they x drilled it BUT only drilled one extra hole (instead of two) then they grub srewed it but went too deep and blocked the oil way all together causing is to wear the shells out and because it got so hot locked the engine up and the flywheel turned on the crank which was then scrap (ulta light steel billet). the old man i spoke to said i didnt know what i was talking about when i rang him to tell him so i went down to his shop and chucked it on the bench and tell me what was wrong which hey presto he apolagized and made me a proper one.
the head i brought from them was ground too deep into the chambers which caused it to crack on the inside and seep.
i went to them as they were cheap, there cheap for a reason!
it was about 5 years ago now but ive learnt my lesson, id rather got to the like of morspeed, med, or swiftune and pay ££££'s reather than going chep and getting rubbish!
#7 holmesy
holmesy
  • 879 posts
Posted 19 December 2012 - 09:00 PM
oi get off my account! and thank you bully for that, its does seem that that rush things and dont take care when i have looked at some other reviews of them
#8 bully
bully
  • 51 posts
Posted 19 December 2012 - 09:01 PM
engine builders ive used are morspeed good work great prices but lead time was to long for me as needed engine asap
med quaily engineering and ok prices
swiftune THE BEST but probably one of the dearest but for a good reason, nick knows his stuff!
my current engine is 50/50 med and swiftune!
simon at morspeed used to work for med so hes knows his stuff too
theres others like sh engineering, skip tune but havent used them
and one you carnt find easy is parker power used ex autograss racer and knows his minis i brouht the clubman im racing from him
#9 holmesy
holmesy
  • 879 posts
Posted 19 December 2012 - 09:02 PM
what about miniSpeed?
#10 bully
bully
  • 51 posts
Posted 19 December 2012 - 09:05 PM
ive brought spares from them as well as minisport and minispares but not had engine work done by them
#11 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 19 December 2012 - 09:16 PM
Things like that happen anywhere when you are machining the life out of parts for racing
#12 aspicer0
aspicer0
  • 28 posts
Posted 19 December 2012 - 09:58 PM
I have not purchased an engine from mini speed but I have purchased a cylinder head and I had no issues with it and the service was fantastic. a friend of mine purchased an engine from them and he has had it two years not had any problems.
another option is to go for a second hand engine from a company named MINI technique they helped me with a problem I had for MOT
#13 holmesy
holmesy
  • 879 posts
Posted 19 December 2012 - 10:19 PM
i like the idea of putting my head and recon gearbox to this= http://www.minispeed...t-omega-pistons
#14 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 19 December 2012 - 10:36 PM
I purchased a head from Jonspeed a few years back.
Asked for it to be black. It turned up red with an awful paint job! it was a stage 3 998 head and the work was good and gave a good power increase (although i never had it on a rolling road).
I complained and got a free sportex exhaust so it wasn't all bad!
Just tell them not to let the apprentice paint it....
#15 Wil_h
Wil_h
  • 3,244 posts
Posted 20 December 2012 - 07:59 AM
I had them build my first 998 turbo engine. it wasn't a complicated build and I defined the requirements quite well. I paid for the crank to be nitrided, it wasn't, but at the time I didn't know what to look for. A number of other errors led to the engine failing prematurely.
However, the head he did was very nice for the money. I personally wouldn't go back, but if you only want a straighforward build, you'll get what you pay for.
