Offset Boring Ya Or Nay
9 replies to this topic
#1 Mini118118
Mini118118
  • 86 posts
Posted 12 November 2012 - 08:59 AM
Hi everyone i have a 1275 block that i am looking to get bored to a 1380 i have read various things about wether to offset bore or not can i have a few opinions please.. its never going to see a race track but it going to be turbo charged and i already have the 73.5mm 11cc Powermax pistons..
your thoughts would be appreciated..thanks
#2 Cooperman
  • 23,273 posts
Posted 12 November 2012 - 12:31 PM
You really do need to offset bore to go to 1380 (if you must go to 1380 - 1330 is just as good and doesn't require offset boring). Without offset boring cylinders 2 & 3 become very close and it's difficult to get the head gasket to last..
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 12 November 2012 - 12:43 PM
Is your 1275 on standard bore? I've got a +0.030 which needs a rebore and you could have cheap, then you could keep your standard bore block!
#4 mike.
mike.
  • 6,176 posts
Posted 12 November 2012 - 12:48 PM
The downfall is that once offset bored the block is scrap once its bores are worn. If you have a 1275 block it can be rebored 2 or 3 times before its scrap.
If you go straight to 1380, then the bores get worn (which could be quite quickly in a high revving engine) then the block is scrap and you'd need to find another one. 1275's are getting harder and harder to find now too.
#5 Cooperman
  • 23,273 posts
Posted 12 November 2012 - 04:24 PM
Anth no more new ones are ever going to be made!
If you are building it for out-and-out competition it's a different matter as 1/10ths of seconds on a lap time count, but for road use the difference between 1330 and 1380 will really never be noticed.
#6 86mayfair
86mayfair
  • 557 posts
Posted 12 November 2012 - 04:49 PM
NAYY!!! Save the A-Series!!
#7 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 12 November 2012 - 05:15 PM
+ 1 on that
#8 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 12 November 2012 - 05:19 PM
and that !! .....well I didnt any way
#9 JimmyB
JimmyB
  • 51 posts
  • Local Club: Minis Manawatu
Posted 14 November 2012 - 08:31 AM
This topic has come up many times and I have often wondered why a 1380 cannot be sleeved back down to re-life it. I believe AC Dodd has a solution to be able to re-use blocks bored to 1380 according to ML motorsport website. Link below
http://www.mlmotorsp...id=83&Itemid=30
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,738 posts
Posted 14 November 2012 - 08:49 AM
Just out of interest I offset bore every block that need to go big enout to allow it. Ie if I bore from STD to +0.060" it is offset. If I bore from STD to +0.040" I offset a smllaer amount. This extends the useful life of a block. With aftermarket liners it is easily possible to resleeve back to stock to give more life, it just costs £££.
Offset boring should be considered the way to go to conserve block stocks.
AC
