Classic Front Spot/fog Light Positioning.
12 replies to this topic
#1 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 25 October 2012 - 08:52 PM
My dad came back from the Malvern show with a front spot light and front fog light.
From a 60's/70's vintage, im unsure where to mount them on the front bumper.
Does anyone have any photos of such classic lights mounted on minis/similar classic car? Maybe a VW camper or something?
Thinking of mounting them next to each other, on the passenger side of the front bumper.
#2 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 25 October 2012 - 09:20 PM
Found this with a front spotlight one.
Not a mini and not a great deal of help.
Really struggling with what to do with them
Edited by GTIAlex06, 25 October 2012 - 09:21 PM.
#3 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 25 October 2012 - 09:43 PM
Mount them on the wings, like they used to with all old cars. Then the passenger would direct its beam
#4 minimarco
minimarco
  • 1,950 posts
Posted 25 October 2012 - 09:58 PM
You should sell them to me :shifty:
Maybe you don't want to buy another hood, but I always thought George Harrisons mini looked cool with spots in the hood. Kinda like how rally porsches mount theirs.
Edited by minimarco, 25 October 2012 - 10:00 PM.
#5 CMXCVIII
CMXCVIII
  • 374 posts
Posted 26 October 2012 - 06:32 AM
In period, they would have been mounted on the bumper - or overriders - with the foglight on the nearside!
So the opposite way round from your first photo. :-)
#6 Joseph-C
Joseph-C
  • 383 posts
Posted 26 October 2012 - 12:15 PM
how would these have been wired up?
the fog on a switch and the spot connected to main beams?
#7 CMXCVIII
CMXCVIII
  • 374 posts
Posted 27 October 2012 - 08:48 AM
They could have been, or wired together on one switch - or wired on two separate switches to look even flashier on the dashboard!
It's not totally legal these days to have one or other auxiliary light illuminating on its own. ;D
#8 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 27 October 2012 - 11:32 AM
So if im right, I can't mount these drilled straight through the bumper as it will just flex and bend? So they either have to go through the lip that the bumper is mounted to or a spot light bar? (or though the bonnet/wings ;) )
#9 mingy
mingy
  • 930 posts
Posted 27 October 2012 - 06:30 PM
It would be advisable to mount your spots on a purpose made bracket, but to be legal you should have two of the same type spots and wire them through a separate switch and relay ie: spotlights on a switch via a relay connected to your main beam wire. A pair of fogs should be wired to a switch via a relay. I have wired mine up like this and it works well.
#10 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 27 October 2012 - 06:37 PM
So is it not legal for me to wire these up separately? I.e The yellow fog on a totally seperate switch to the rear fog and the front spot light not wired in with the main beams?
#11 mingy
mingy
  • 930 posts
Posted 27 October 2012 - 07:28 PM
I may have not explained the mounting and wiring details clearly, but my next door neighbour is a retired motorway patrol officer and he advised me of the relevant laws regarding auxilliary lights on motor vehicles as far as he remembers.
1/ You must be able to switch the spotlights independently from your main beam.
2/ " " " " " " " foglights " " " " " and rear foglight/s.
3/ Any rear foglights must be mounted to the drivers side of the vehicle and independently switched.
4/ Rear foglights are not a legal requirement on cars manufactured before a certain age,ie if it did not have one fitted from the manufacturer then you do not have to install one.
#12 minimarco
minimarco
  • 1,950 posts
Posted 27 October 2012 - 07:54 PM
available from bryan purves http://www.bryanpurv...ewminimenu.html
They mount like this
#13 Ethel
  • 25,794 posts
Posted 27 October 2012 - 08:20 PM
The date is 1 April 1980.
Spots should go off when you dip the headlights - using the same switch. Easily done, just use a relay operated from the main beam, via your spotlight switch.
I'm pretty sure a single front fog should be mounted on the driver's side. There are rules about how far it should be from the vehicle edge, they'll be on the web.
They are: Regulation 20, schedule 6 of The Road Vehicles Lighting Regulations 1989
In short, if you only have 1 fog you can put it anywhere but you must also use dipped beam. If you have a pair you can use them in place of the headlights, but they must be within 40cm of the vehicle edge and within 120cm of the ground, not a huge restriction on a Mini :P
