Dutch Micra-Engined Mini
46 replies to this topic
#1 MiniNissan
MiniNissan
  • 24 posts
Posted 02 August 2012 - 08:21 PM
Hi, My name is Bart Verstappen from the Netherlands. I've been reading everybody's topics and story's about they're cars for some time now, and decided it was time to make a topic of my own conversion. I started about a year ago. Ongoing reliability-problems with the original a-series made me look into other options.
Since i work for a nissan dealership, the choice of the Micra CG13 engine almost came natural. So i bought a 94 1.0 model and took out the gearbox, selector mechanism, and some other small parts. everything that was left i took to a local scrapyard and traded in to a CG13 with only 29000km's on it.
i made a frame, which uses the original towers from the mini's subrame, but the rest is a tubular custom frame.
after further strenghtening and powdercoat.
How the engine sits in the frame.
made up some engine mounts.
Because of it being LHD i had to reposition the steering rack, a bit lower.
modified the bulkhead to clear the carbs.
painted the engine bay and fitted everything back together.
how it looks now.
the carbs are Yamaha R1 carbs and the radiator is a from a Mini MPI. i have a lot more pictures on my phone and once i figured out how to get them on the computer i will post them up.
I must say i'm very pleased with the conversion. after a few test drives is definitetly feels good, and as quick as the 1293 stage 4 it had before. the 1.0 box is maybe a bit short with the 10" wheels. but now i have a fifth gear which makes up for it.
#2 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 02 August 2012 - 08:28 PM
Looks excellent, buddy!
Very neatly executed.
I'm considering a CG13 for my conversion, so the more pictures the better!
I'll be using an automatic transmission, don't suppose you know if they're much bigger - working in a dealer and all ;-)
#3 l_jonez
l_jonez
  • 1,453 posts
Posted 03 August 2012 - 05:28 PM
Looks great, Ive always likes tubular frames
mine is the same, bike carbs and mpi rad up front. How cone you had to cut the bulkhead ?
#4 l_jonez
l_jonez
  • 1,453 posts
Posted 03 August 2012 - 05:31 PM
Ignore me, just noticed you engine is much further back than mine
Edited by l_jonez, 03 August 2012 - 05:33 PM.
#5 rids
rids
  • 670 posts
Posted 03 August 2012 - 07:11 PM
very neat.
#6 MiniNissan
MiniNissan
  • 24 posts
Posted 03 August 2012 - 07:14 PM
Thanks man, The K11 CVT automatic box is alot bigger then the manual box. however it might be possible to adapt the older K10 automatic box to the CG13 engine.
ik think its worth looking into this. although i'm sure that a MA10/12 flywheel does not fit a CG engine.
maybe someone else on here tried it before?
#7 MiniNissan
MiniNissan
  • 24 posts
Posted 03 August 2012 - 07:20 PM
The engine is as far back as possible, the waterpump only just misses the righthand subframe tower, i could get away with the standard bulkhead i guess, but now i can use a more desirable and longer inlet manifold. What bike are you carbs from, how do you think it is on fuelling? mine runs a little rich it seems, but pick up is perfect, bit sensitive on throttle tough.
Edited by MiniNissan, 03 August 2012 - 07:22 PM.
#8 l_jonez
l_jonez
  • 1,453 posts
Posted 03 August 2012 - 07:46 PM
Mine are from a 750zzr I believe. I'm currently running a 1.0 engine and it seems a bit rich. Hopefully the 1.3 will go in next week and I'm fitting a wide band lamda sensor at the same time so i can get the fueling right
#9 MiniNissan
MiniNissan
  • 24 posts
Posted 06 August 2012 - 10:20 AM
Cool, i also thought about fitting a lambda-sensor on mine, i'll be watching your thread to see what your results are.
how do you rate the megajolt system on the micra engine? Fully mappable electronic ignition is one of my future mods on the car.
#10 MiniNissan
MiniNissan
  • 24 posts
Posted 06 August 2012 - 10:32 AM
I found out how i get my pictures from my phone to my computer and on here :proud: , here are few more pictures,
The gear selection only uses a home made bracket, the Nissan lever an shortened rod.
and on the car, a carbon fibre cover will be made to prevent splashing water coming in the car
front mounted alternator
exhaust downpipe, with flexible joint mated to mini's stainless exhaust system
carbs are a snug fit in the modded bulkhead, not touching under accelaration or decelaration though.
Edited by MiniNissan, 06 August 2012 - 10:35 AM.
#11 l_jonez
l_jonez
  • 1,453 posts
Posted 06 August 2012 - 04:57 PM
I love Megajolt, it works brilliantly and is relatively cheap, I'll never run a dizzy again.
What you planning on using for ignition to start with?
#12 Tomm
Tomm
  • 2,461 posts
Posted 07 August 2012 - 03:44 PM
Wow, this looks fantastic! That engine bay looks so clean and tidy!
#13 evansisgreat
evansisgreat
  • 1,096 posts
  • Local Club: Not yet
Posted 09 August 2012 - 10:56 AM
Really neat installation, do you have any more pictures of how the subframe gets around the inner wings? I've never seen a subframe design that has support from the top of the suspension towers down to the front support that didn't require removal of the inner wings, would be great to see how you've done it. Hope my project turns out as neat as yours.
#14 l_jonez
l_jonez
  • 1,453 posts
Posted 09 August 2012 - 04:37 PM
dont want to hi-jack the thread but check out my build, my subframe also clears the inner wings. ( i haven't got any because of a removable front but the frame was tested in a normal front and there was good clearance)
#15 tangoed
tangoed
  • 22 posts
Posted 09 August 2012 - 06:01 PM
is that the nissan alternator with the standered belt and brackets still fitting behind the grill ?
