5 Speed Gearbox
Posted 13 July 2012 - 07:11 PM
just been playing need for speed shift 2 and just noticed it goes to 5th gear and im like WHAT :S lol ???
Posted 13 July 2012 - 07:12 PM
Posted 13 July 2012 - 07:14 PM
Quote:
You'll get the best of both worlds - acceleration and easy cruising - with this Mini Spares Evolution five speed. The Final drive ratio ratio is 3.44, so you'll have the acceleration as before through fourth gear. But with the overdrive fifth gear the effective final drive is now 3.037, great for highway cruising. Fully assembled, ready to install.(Available in Rod-change only) Covered under guarantee for parts only with NO labour claim costs, Other variants such as straight cut or with x pin difffs available. Remember! Although this gearbox by design is infinitely stronger, the weakest part of any A plus gearbox is the standard 2nd gear Plus the overworked new 5th gear and this box is no different. Not for Turbos where boost is adjustable or powerful engines. Fitted in 1275cc-1380cc including Minispares old 8 port head road going car with 286 camshaft it has proven ultra reliable.
There are 58 extra parts including machining.
Owing to the closure of Powertrain all gear tooling and manufacture was sold off, so some secondhand parts are used in these gearboxes if in perfect condition. Apart from laygear and 1ST motion shaft which are different from standard parts the other New parts nearly always used are 1ST/2nd synchro,reverse gear, 2nd gear and diff plus the extra 5 speed gears.
KAD 5-Speed:
The KAD 5 speed race gearbox is available as a self assembly kit or built into a gear casing for the addition of your existing gear train components.
http://www.kentautod...eed-dog-gearset
Edited by mab01uk, 13 July 2012 - 07:19 PM.
Posted 13 July 2012 - 07:15 PM
Posted 13 July 2012 - 07:33 PM
they are expen$ive
Posted 15 July 2012 - 07:08 AM
Posted 15 July 2012 - 07:19 AM
Posted 15 July 2012 - 02:34 PM
Posted 15 July 2012 - 02:38 PM
Posted 15 July 2012 - 02:53 PM
Posted 15 July 2012 - 07:29 PM
You "could" get a 6 speed gearbox for the mini, not that JKD have made anything in the last 10 to 20 years
I never said it was new - although some times a NOS one turns up
a bit like the Mini itself
Posted 15 July 2012 - 11:09 PM
Interesting 6-Speed Sequential Mini Gearbox below using std honda cbr 1100 RR bike gearset:
More:
http://www.turbomini...p=vt&tid=439368
http://www.ausmini.c...pic.php?t=65033
KG Engineering in Melborne Australia below also made 5 and 6-speed Mini gearboxes a few years back:
http://ausmini.com/forums/viewtopic.php?t=35779&view=next&sid=ada0f5f1ebbf577d3283fe096916b4ff
Edited by mab01uk, 15 July 2012 - 11:19 PM.
Posted 15 July 2012 - 11:35 PM
More:
http://ausmini.com/f...283fe096916b4ff
beautiful.
Posted 16 July 2012 - 05:04 PM
http://www.guess-works.com
Edited by classicminidriver, 16 July 2012 - 05:31 PM.
