Micra Mini Track Day Car
#106
Posted 25 April 2013 - 12:40 PM
Interested to see how this car goes - i was told not to bother with a weber on my 1330 - i'd never go back to an SU now. Its been set up and sounds immense.
My uncles Puma engined mk1 escort runs twin 40's - the way it barks throught the webers was worth all the hard work!
#107
Posted 25 April 2013 - 01:29 PM
Sounds like you need a Frankspeed manifold (Frank is a guy on the Micra forum and if you ask nicely he might send a diy kit to mod your manifold for more flow or I think he might do them as well)I hope so im modifying the standard exhaust manifold to try and make it flow better ie gutting the CAT or removing it altogether
http://www.micra.com...eid=84053#84065
http://www.micra.org...67/#post-582307
#108
Posted 25 April 2013 - 03:56 PM
Franks a good bloke and helped me with my engine build .
A 4-2-1 manifold will give better results but will need to be modified to fit. Im sure rids did this to his?
Edited by l_jonez, 25 April 2013 - 03:59 PM.
#109
Posted 25 April 2013 - 07:50 PM
yup I did, modified a micra 4-2-1 tubular manifold to fit.
#110
Posted 25 April 2013 - 09:47 PM
Edited by lucas1amps, 25 April 2013 - 09:48 PM.
#111
Posted 02 May 2013 - 02:09 PM
well loom paid for and done need to get a mega jolt unit and trigger wheel, college work is dominaing atm plus ive had to take the engine out of my mk1 metro for the new 1275 to go in so busy atm!
#112
Posted 21 May 2013 - 12:13 PM
Speak to Chris at trigger-wheels as he is the cheapest unless you want to import MJ from the US directly.
#113
Posted 21 May 2013 - 06:10 PM
defo will cheers david
#114
Posted 24 May 2013 - 06:21 PM
right update time lots of pictures too, work has been commencing on the mini shell the shock mounts and heel board has been made and the manifold components have arrived hopefully manifold will be finished by june 6th as this is when my project report Is due. where the injectors use to be pete is putting in vacuum take off so should make setting up the carbs bit easier. . just wrote a 5000 work report on it cant wait to get the shell back and build it up as a race car! still got cadge to do and the boot floor needs looking at as well as the flinch panel on the drivers side. anyway hers some pictures
#115
Posted 30 May 2013 - 04:39 PM
loving the build!
did i see right earlier that its a LHD???
is there a company making the converted front subframe?
#116
Posted 30 May 2013 - 10:50 PM
cheers buddy! and no its RHD and the subframe was built by myself
#117
Posted 31 May 2013 - 09:34 AM
main things im worrying about with the micra is the location of the gear stick, im not sure if it locates to the same place?
The Micra gear change system is similar to the Mini with the two rods, they just need shortening a bit. Haven't you looked at all the other Micra threads? most have photos of the gear-change and how they've modified them.
This is one lifted up inside the car, none of the others are like this one http://www.theminifo...a-engined-mini/![]()
ah right, saw this and assumed it was yours lol.
keep up the great work anyway
#118
Posted 01 June 2013 - 07:41 AM
cheers buddy up date soon!
#119
Posted 05 July 2013 - 04:17 PM
project has been put on hold might cut my losses and sell up fed up with it all
#120
Posted 05 July 2013 - 08:30 PM
Bing (1)
