I have a 998 metro that is striped down ready for rebuild, before the strip down the engine run great with no smoke etc. but i striped down as was planning on rebuilding to a higher spec, i was going to go to 1061cc with a 940 head etc.
I have now decied to go down the 1275 route.
So you get the whole engine minus the cylinder head and camshaft. The crankshaft is in great condition and would not need a regrind just re shelling also the bores are not to bad condition and could be honed with new piston rings as the pistons are in perfect condition. It comes with all the clutch and timming covers also a verto flywheel with a nearly new verto clutch kit which alone is £80. I also will include the distributor and all the oil pipes etc.
I am after £50 for the lot.
Located in Maidstone Kent.
Any questions please ask.
Any more pictures please ask.
Edited by andymini12, 05 June 2012 - 08:45 PM.
This topic is locked
