Rev Counter
Posted 27 April 2012 - 08:43 PM
thanks, ben
Posted 27 April 2012 - 08:52 PM
Posted 27 April 2012 - 08:54 PM
much easier seeing a labeled diagram! taaDoes this help?
Posted 27 April 2012 - 09:07 PM
Edited by minimarco, 27 April 2012 - 09:07 PM.
Posted 27 April 2012 - 09:12 PM
Posted 27 April 2012 - 10:34 PM
the car is a 1990 studio 2 998cc, except it has a different engineWhat year mini do you have? If its a later one with the 2 clocks in line with the driver, there should be two wires for the optional rev counter under your clocks. They should be two green wires each with a different colour tracer. I can find out which if you'd like? Saves running wires to the coil
Posted 28 April 2012 - 10:05 AM
Edited by adam_93rio, 28 April 2012 - 10:06 AM.
Posted 30 April 2012 - 06:20 PM
this gauge requires 4 wires tho?Behind your clocks you will find a green/orange wire and a black/white wire, these are the connections for the rev counter
Posted 30 April 2012 - 06:22 PM
yep, those two for the rev counter, another for earth, and another to make it light up.
Posted 30 April 2012 - 06:25 PM
so these 2 are basically, battery and coil wires? and i see yeah id still have to set up 2 more wires for lighting and earth?
Posted 30 April 2012 - 06:27 PM
Posted 01 May 2012 - 06:05 PM
these wires?
Posted 01 May 2012 - 06:24 PM
Its easy to pin point these wires if you have a multimeter, just look for which voltages appear when you put the ignition on, and headlights on etc.
Posted 03 May 2012 - 08:13 PM
