I need some help working out how to remove the engine as I've read through the Haynes manual but am still left with some questions - mainly does my car have one of those? What does it look like?? I work much better with pictures
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sideways.gif)
I've got at 1984 Mini Mayfair
I found this old post http://www.theminifo...__fromsearch__1 which said remove these items below:
Accelerator cable,
Choke cable,
Heater cable,
Heater hoses ( one to head and one to bottom hose )
Top engine steady
Bottom gearbox steady - Is this present in a 1984 mini - what does it look like?
Clutch slave from housing - Does this need draining first?
Starter solenoid ( if on inner wing ) - Is this present in a 1984 mini - what does it look like?
Alternator, just gets in the way...
Gearshift mechanism - where would I disconnect this from on a 1984 mini?
Exhaust, if LCB the you can just separate it at the Y piece.
drive shafts ( to do this remove top ball joint and lean hub back )
Brake servo - Is this present in a 1984 mini - what does it look like?
Dizzy cap and rotor arm..
Haynes says to undo and remove the upper suspension arm rebound rubber and replace it with a wooden wedge - Why? what does the rebound rubber look like?
At what point does the engine need to be supported - just to ensure I don't take everything off and it falls on the floor
In case you hadn't guessed it already am a novice and could do with all the help I can get.
Thanks for any help in advance
Chris
