Nightmare Fitting Deluxe Wheel Arch Trim
Posted 19 February 2012 - 07:31 PM
Posted 20 February 2012 - 07:27 PM
This type of trim is very difficult to fit. We tried this on my Mini on a hot June day a few years back and even then it was a nightmare!
When I had another go I heated the trim by leaving it in front of a calor gas heater until it felt quite hot to touch.
I also used a hot air gun during application to keep the trim as flexible as possible, this makes it a lot easier to fit and less likely to kink, especially where the bottom of the wheel arches join the sill.
As it cools it then grips to the lip of the body.
Hope this helps!
Steve.
Posted 20 February 2012 - 08:52 PM
Posted 20 February 2012 - 10:54 PM
Posted 13 November 2014 - 12:42 AM
Hi Leekr,
Sorry not to reply for giving an answer to your question, I'm searching for the same arches as you've got on your car (not too wide and going down the bumper at the back).
Can you (or anyone else) tell me where I can find those items.
Thank you in advance
Posted 13 November 2014 - 07:29 AM
Pretty sure they are the huddersfield mini spares group two narrow that wrap around.Hi Leekr,
http://www.minispare...r-classic-mini/
Posted 13 November 2014 - 02:59 PM
Where did you get the arch trim from? I've fitted the deluxe trim from Mini Spares to 4 cars this year and I'm sure none of it has come rolled with the clear portion facing outwards.
All I I do is pour about 4 litres of boiling water into a bucket with the trim sat in the bottom (one side at a time) and then slowly work it on starting from the back and working forwards. Some times I find it's necessary to get a cup and pour some more water over to soften the trim more for the bends at the A-panel and bottom on the quarters but I've never had a kink.
Posted 13 November 2014 - 03:05 PM
Looks like done in a rush and putting too much force or the trim was not warm enough. And FG arches dont help the fitment either.
Honestly i'd fit the normal trim over these arches, and the deluxe on archless cars.
Its a long and patience requiring job i know..but take plenty of time and heat.
Posted 13 November 2014 - 10:25 PM
Thank you Coxie, your link seems to be the right one.
Huddersfield answer to my questions really quickly and confirm that those rear arches are continuing under the bumper lip.
It seems like I've just found a christmas gift for my mini...
