Shed. (Picture Heavy).
21 replies to this topic
#1 SolarB
SolarB
  • 1,384 posts
Posted 10 January 2012 - 11:17 AM
Now the Mini is finished (well, as finished as they ever get) I’ve been having a go at some woodwork and building a shed at the end of the garden. I wish I’d built the shed before starting the Mini restoration, life would have been much easier with a separate workshop away from the garage.
The old shed at the bottom of the garden, to be replaced with something a little more useable.
Making room.
Ordered a shed load of pressure treated timber. Floor and walls are 4”x2”, roof is built from 6”x2”.
Frame starts to go up for a wood structure 7m x 4m x 2.5m with a very shallow pitched roof and a porch at the front. Walls were built on the ground and then lifted into place. The whole thing rests on three rows of bricks which in turn sit on three rows of paving stones. This gives a reasonable height under the floor for the air to circulate.
Front and one side to be clad in cedar.
Front of the shed has an overhang. Green posts are temporary supports as the porch is self supporting. Roof has a very shallow pitch to keep the highest point below 2.5m. Wife working well at this point.
Brother helps while the dog has a nap.
Front roof was designed for 2 tons of concrete roof tiles, hence the large quantity of 6x2 timber.
Green sheet on the grass is plastic coated steel cladding. This is for the right hand side, the rear side and the rear roof section. It’s one of the cheapest forms of covering and doesn’t require much maintenance.
First steel sheet on the rear roof.
Two walls clad, dog still resting.
Front roof design changed from tiles to cedar cladding. The cedar is probably around one tenth of the weight of the original clay tiles which means the roof is now grossly over engineered, but I guess its better this way around rather than under engineered. Wife very happy that the roof is on.
Cladding being fitted to one of the side walls. This wall is visible from my neighbours garden and we wanted it to look nice and blend in with their garden buildings. Coincidently, he supplied us with the cladding.
Trial fit of the double glazed windows. These were being thrown out by some friends who were having an extension.
Window and door surrounds fitted. These were cut from a thick cedar plank and match the vertical end trim on each corner. Cladding is fitted between the vertical trims to give a more finished appearance.
Fully clad and watertight.
Windows toned down with a little paint. Wood stacked under the windows are pressure treaded scaffold boards for the floor.
Fitting the floor. Much cheaper and twice the thickness of the 18mm ply I had originally considered.
Walls and roof are insulated with 2” polystyrene sheets.
Polystyrene insulation finished, skylights will be double glazed with conservatory roofing polycarbonate sheets.
Double doors. Main door is wide enough to get bikes through without twisting the handlebars. Small second door might be needed for really large items. Electrics temporarily transferred from original shed.
Interior is lined with 12mm ply.
Outside nearly finished, only needing a gutter and some plants growing against it.
#2 freshairmini
freshairmini
  • 1,718 posts
Posted 10 January 2012 - 11:28 AM
That is awesome! I wish I had a shed like/could build one my self :D
Did you design all that yourself?
#3 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 10 January 2012 - 11:49 AM
Was kind of hoping to see some sort of motorised shed >_<
Lovely, as above, did you design it yourself? Really jealous of all that space.
#4 Mini-Mad-Craig
Posted 10 January 2012 - 11:51 AM
That's gorgeous mate, nice work
#5 SolarB
SolarB
  • 1,384 posts
Posted 10 January 2012 - 12:44 PM
Thanks for the comments. We designed it ourselves, but to be honest if you can work on a car you can certainly design and build a shed. It's just a shame there's no vehicular access to the garden. If there was, the shed would have been much bigger. :proud:
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 10 January 2012 - 12:48 PM
Maybe your next project can be ''underground access tunnel''
#7 Solarbotherhalf
Solarbotherhalf
    Starting My Mini Up
  • 1 posts
Posted 10 January 2012 - 01:42 PM
Please don't give him any ideas! underground is about the only part left that he can do anything to! ps v.proud of mini - love driving it.
#8 Beej123
Beej123
  • 1,184 posts
  • Local Club: Splinters Mini Club
Posted 11 January 2012 - 04:34 PM
Nice to see this, mine is in the final planning stages! 6x5.5 metres in total and it will be to house the mini :D
Can't see mine looking this good though!
#9 Juju
Juju
  • 3,620 posts
Posted 11 January 2012 - 04:50 PM
Very impressive, Mr G! I'd call that a 'house' rather than a shed!
Beautiful red cedar. :wub: Is it Canadian?
Are you sure the dog's just asleep? :huh:
#10 SolarB
SolarB
  • 1,384 posts
Posted 12 January 2012 - 02:16 PM
Now you could really have something there!
What are you doing on here?
No, just good old Surrey cedar. Apparently it was lying in someone's field for a year before my neighbour acquired it and ran it through the saw mill. It'll turn grey in a year which is a little saddening as the colour at the moment is really something else when the sun rise catches it.
Difficult to tell sometimes.
Edited by SolarB, 12 January 2012 - 02:22 PM.
#11 Beej123
Beej123
  • 1,184 posts
Posted 12 January 2012 - 02:21 PM
I actually burst out laughing when I read that! haha
#12 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 12 January 2012 - 02:37 PM
+1!
#13 MrBounce
MrBounce
  • 2,613 posts
Posted 12 January 2012 - 08:21 PM
Love this ;D
#14 MGBailey007
MGBailey007
  • Validating
  • 725 posts
  • Local Club: North West Mini Club
Posted 15 January 2012 - 02:16 PM
that's amazing,
#15 bcjames
bcjames
  • 2,728 posts
Posted 15 January 2012 - 02:20 PM
That is one mighty fine shed sir!
