thats cool dont worry, the horn i just sprayed it in the trumpet hole, i believe i took the horn off and and held it so the wd would work its way in. Then connected it up again and bam, it was working.
Really? WD40 straight in the horn where the noise emanates from? I'll give it a try. Thanks for the tip.
I have the same problem
Did it just stop working for you mate? Or was it gradual?
I'd check the horn is getting power when it should, and is earthed. Could be worth checking the contacts on the plug socket and making sure they are clean, or that it's even plugged in correctly.
You could also remove the airbag and check the horn connection under there, mine had an issue there. This doesn't involve removing the steering wheel, but you need to disconnect the battery for half an hour before playing with the SRS system. To replace the coupler requires removing the wheel, but it's just one nut and it's easy to line up again assuming to parked with the wheels straight.
What fuse do you have listed just for the horn? Looking in the glovebox handbook, I can't see a separate listing.
Hmmm...maybe I was wrong with believing there is a dedicated fuse just for the horn. I was sure that was right, maybe i'm wrong. I'll take the horn off and have a good look at it, spray some WD40 on the connectors and in the trumpet hole itself. The fact that it was making a noise, although slightly muted, then stopped makes me think that a wee clean with WD40 might do the trick...we'll soon find out though.
