Mini Mk3 Onwards Sliding Window Door Conversion Kit
9 replies to this topic
#1 mab01uk
mab01uk
  • 12,293 posts
Posted 30 October 2011 - 11:52 PM
Anyone tried these Sliding window conversion kits to fit the later MK3 style doors:
Full conversion kit containing everything you need to fit the MK1 style 2 piece sliding windows into the MK3 doors
Kit Contains the following parts (For 2 x doors)
2 x Door conversion plates
2 x chrome inner rails
2 x lower rubber channels
2 x upper rubber door frame channels
4 x MK1 catches
1 x Fitting Instructions
Conversion involves permanent modification to inner door skin.
Legal conversion for historic rallying as the last works carswere using this conversion in the early 70's
Price £210.00 (+ 20% VAT)
** Price does not include polycarbonate windows **
More:
http://www.plastics4...88-298-856-732/
Edited by mab01uk, 31 October 2011 - 12:01 AM.
#2 jral4328
jral4328
  • 42 posts
Posted 31 October 2011 - 12:24 AM
No but me like.
#3 furiousjim
furiousjim
  • 151 posts
Posted 31 October 2011 - 01:21 AM
I have to to say, they look damn impressive, plus saving weight with getting rid of the whole window winder mechanism
#4 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 31 October 2011 - 03:24 AM
Looks pretty good. Iv never been In a mini with sliding windows, would they be easy to push apart or are the catches good enough to stop scummers breaking in without smashing the window?
#5 mab01uk
mab01uk
  • 12,293 posts
Posted 31 October 2011 - 08:56 AM
Having owned several original sliding window Mini's, I would say they are much easier to force an entry into the car without breaking a window, the catches have small pins which lock into holes in the runners but they can never be quite as secure as a wind down window. (at least in Mini security terms.........which is not great even on the the later cars).
Glass windows would also be better than most plastics for road use, but usually the taller Mk3 door frame means Mk1/2 sliding glass won't fit, so flat laminated glass would have to be specially cut and drilled to suit.
Edited by mab01uk, 31 October 2011 - 08:58 AM.
#6 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 31 October 2011 - 12:16 PM
Usually found on logbook specials.;-(
#7 midridge2
midridge2
  • 1,794 posts
Posted 31 October 2011 - 03:42 PM
its missing the centre vertical draught excluder.
#8 mab01uk
mab01uk
  • 12,293 posts
Posted 01 November 2011 - 08:45 PM
For water drainage from the sliding window channels on a road going Mini, you will also need to fit the Mk1, Mk 2 drain tubes and the 2 rubber pipes down to drain holes in the base of the doors.
Good company to deal with in my experience and a fellow MCR member. :thumbsup:
#9 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 01 November 2011 - 08:52 PM
oh me like! might have to purchaise some of them there slidey winders!
#10 puggered
puggered
    previously known as Mini15
  • 708 posts
Posted 01 November 2011 - 11:32 PM
Looks good!
