Fuel Tank Strap Mounting Point
32 replies to this topic
#16 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,031 posts
  • Name: Neil
Posted 05 August 2011 - 07:49 PM
Its called a clip nut and i cannot remember what size it supposed to be. It will either be 1/4" or 5/16"ths but i have a feeling its a 1/4".
They do give you some room to manoeuvre when fitting the tank. I did make my bracket (i pattern copied it off the original) and seam welded it on.
#17 tractor
tractor
  • 662 posts
Posted 26 July 2012 - 10:07 AM
Here you go
hey guys and girls I’ve got exactly the same issue here,
Somehow we're not able to see the picture that R1minimagic posted, could someone post a picture of where the mounting point is supposed to be relative to where the tank sits?
I'll probably get the proper bracket from somerfords if they still do them, it doesn't seem worth the hassle of making one when you can get one for less than a tenner
thanks chris
#18 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 26 July 2012 - 12:52 PM
Here's some pictures that may help you.
#19 tractor
tractor
  • 662 posts
Posted 26 July 2012 - 01:07 PM
hi sonnik thats perfect thanks for doing that it's much apprieciated
i got an idea now where the anchor should sit, looks like the lip of the tank butts up against the upright of the bracket and offers some oppostion to the strap
trac
Edited by tractor, 26 July 2012 - 01:10 PM.
#20 mike.
mike.
  • 6,176 posts
Posted 26 July 2012 - 01:11 PM
When I did mine I found it wasn't exactly critical where it goes, aslong as the tank strap and bolt can fit squarly without being twisted.
#21 tractor
tractor
  • 662 posts
Posted 26 July 2012 - 01:25 PM
don't suppose you still have the part number do you mike? i've looked on somerford minis site and cant find the part
Edited by tractor, 26 July 2012 - 01:26 PM.
#22 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 26 July 2012 - 01:28 PM
Here it is on the somerford website.
33 REPAN018 ANCHOR BRACKET, fuel tank mounting 1 1976 on
#23 tractor
tractor
  • 662 posts
Posted 26 July 2012 - 01:31 PM
perfect thanks for all your help guys,
heres the link just in case some else stumbles across this thread in the futur
http://www.somerford...roducts_id=1219
#24 TimWright
TimWright
  • 12 posts
Posted 13 February 2013 - 11:07 PM
Thanks guys for this, it's been bugging me for a few days, where to fix a bracket!
#25 TimWright
TimWright
  • 12 posts
Posted 16 February 2013 - 08:43 AM
Is there anything holding the tank in at the top? Or is it just the strap pulling the tank into the corner of the shell?
What would be really good on this feed is for a picture of the tank fitted from the outside above with the boot seal removed so you can see the seam of the tanks alignment with the car and also with the fixed bottom bracket in view. If I remember correctly its sort of in on the wonk where the top part of the seam of the tank is in further than the bottom part of the seam? I may have had a wonky mini though ;-)
I searched for quite a while for shots of people's striped out boots but all the photos you find are taken from low down so you cannot see the lower bracket.
That's a long ramble hope it makes sense.
Thanks for the other pictures they are a great help too.
#26 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 18 February 2013 - 02:38 PM
See if these help
Tank is only slaved in at the moment.
#27 nz_seamless
nz_seamless
  • 68 posts
Posted 21 September 2013 - 10:52 PM
Neil you are a star, I am putting a 7.5 gal into a mk3 shell and you have just given me everything I need to fab this up. A whole lot of thanks from down here in NZ.
#28 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 04 October 2013 - 10:35 PM
Is there anything under the tank for it to sit on? I pulled mine apart for respray and I am meticulas about keeping parts altogether.But when it came to refitting the tank it appears there's nothing. I have the rubber ring for filler and strap insulation but that's it. is there anything that goes against the bracket near the top strap bolt? How about the lower edge, it seems to just sit on floor.
#29 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 09 October 2013 - 06:50 PM
On the early cars there is a rail but on the later ones nothing.
This is from the somerfordminis website.
http://www.somerford...&id=1&chapter=5
24 14A6867 CHANNEL, fuel tank support 1 1959-75; standard LH tank only
#30 1984mini25
1984mini25
  • 8,784 posts
Posted 27 September 2016 - 09:09 PM
To save making a new topic for basically the same thing, does this measurement look right for the location of the bracket?
