Bike Carb Conversion
Posted 18 May 2011 - 09:56 AM
After searching the web for info on what carbs were fitted to what bikes, I came across the 2 cylinder Yamaha 850TDM, which obviously only uses two carbs, rather than the usual bank of four which are often sold on E-bay. These carbs are 38mm choke size, therefore equivalent to the 1 1/2” SU and being a modern bike, has a TPS fitted as standard, so ideal for the Megajolt system which I installed in 2006 (although at present runs on the MAP system).
So the search for suitable carbs began … with E-bay coming up trumps with a set of 1999/2000 carbs at a price of just £30 including p&p, ideal! I already had a twin SU manifold, which I was going to use to mount the carbs onto. E-bay again, and SDRAM 600 mounting rubbers £15 for a set of four were obtained.
After receiving the carbs, it became apparent that the angle of the carbs wasn’t right for the carb fuel bowls, so I acquired a lump of aluminum (£20) to mill a 10 degree wedge to bring the bowls level.
Then began the fun bit, respacing the carbs to match the SU manifold. Fortunately my father is a model engineer and was able to do the milling and lathe work.
After a few months of work (part timer!), it came time to mount the carbs onto the engine. Guess what, they fired first time, much to my surprise!! Although they worked, it was apparent that they weren’t set-up, with a big flat spot when you banged open the throttle. Talking of the throttle, the pedal needed modifying, as it ran out of travel only at half pressed.
The rolling road session went well, after a few holes in the carb were blocked up and the main jets changed, we had gained 6 brake and a flatter torque curve.
After a few miles of driving, I am quite pleased with the results, with an engine that feels more responsive (quicker?) but I have a few issues. Firstly the throttle pedal is very light and unfortunately the loud Weber bark has gone!!!
TDM Carbs
Carbs respaced apart
Clearer view
Manifold modified, studs relocated, inlet bores opened up
10 degree wedged spacer fitted
Carbs fitted to manifold
Side view shows wedge
Fitted to engine
Rolling road graph
Posted 18 May 2011 - 10:54 AM
Additional spring on the throttle arm of the carbs helped loads in returning the pedal etc, standard spring isnt strong enough as all is used to do was return the grip when on the bike if that makes sense
Posted 18 May 2011 - 09:25 PM
Posted 18 May 2011 - 11:27 PM
Also what sort of filters are available?
Posted 19 May 2011 - 07:51 AM
George 91 - The bhp is the lower lines on the graph, so 82 at the wheels, which shows a 7 bhp improvement over the Dellorto. The upper lines are the torque curve. As you can see, it is a much flatter line and doesn't drop off when approaching max bhp.
Mike - They sound very similiar to SU's. Although I haven't had twin SU's on the Mini for at least 20 odd years!! They still have a roarty sound though, but not the bark as the Dellorto. You can get "sock" filters made from foam, which I have ordered from Demon Tweeks for around £25 a pair.
Posted 26 May 2011 - 07:19 AM
To alter the super light pedal, you can shorten the pedals leverage ratio.
You need to cut down your pedal and re-dill it for the cable, hacksaw a slot down to the new hole. Then drill a new hole in the bulkhead.
I had already made a new pedal, with the correct leverage, and with the correct full travel, using the original mounting points and hole in the bulkhead. But as Udo has said, the bike carbs are intended for hand throttle. At present I am looking for a correct sized and stronger enough torsion spring to put on the pedal, to stiffen it up.
Posted 26 May 2011 - 07:50 AM
Posted 26 May 2011 - 08:59 PM
lot more than £30 ( , I keep an eye out for the Yam ones. looks the dogs by the way..
Posted 27 May 2011 - 07:15 AM
Hi Rob I was looking at some Ducatti monster carbs , they are 38mm, but they fetch a
I looked at the Ducatti 990 S carbs, which look exactly the same as the Yamaha ones, but as you say, they are more expensive!!!
Posted 28 May 2011 - 01:38 PM
Posted 28 May 2011 - 05:35 PM
Does anybody know of any bike carbs that are 1.25 inches?
how about the mikuni BSR32 twin carbs from a CCM R30/644... they also run upright so there would be no messing about getting the angle right
GL1
Posted 29 May 2011 - 10:23 AM
Posted 29 May 2011 - 07:01 PM
Posted 30 October 2011 - 06:17 AM
Posted 31 October 2011 - 11:42 AM
Don't you find that the carburettors starve for fuel in long turns? Motorcycle carbs are not designed to handle the G forces from lateral acceleration.
No problems at all. Competed on the Cambrian Rally a couple of weeks ago in the forests of North Wales and the tarmac road around the Great Orme.
The bike carbs performed great ... pity about the rocker shaft breaking on stage 3, but after borrowing a shaft assembly from a local garage, we finished, despite the headgasket failing.
Edited by Rob Jones, 31 October 2011 - 11:54 AM.
