![Photo](https://www.theminiforum.co.uk/forums/uploads/profile/photo-thumb-49591.jpg?_r=0)
Pics Of Your Lowered Minis
Posted 27 April 2011 - 08:20 PM
Posted 27 April 2011 - 09:31 PM
![Posted Image](http://i182.photobucket.com/albums/x259/mk1leg/34592_412230501842_513976842_483186.jpg)
I have used Minisport AjustaRide with Spax gas ajustable shocks....
![Posted Image](http://i182.photobucket.com/albums/x259/mk1leg/my%20pics%202/Minirest02003.jpg)
the ajusta rides are set at 3 full turns from lowest setting at rear and 2.5 for front....the shocks are set at 7 clicks (middle)............I have neg camber front and rear...............hope this helps........
![>_<](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/thumbsup.gif)
Edited by mk1leg, 27 April 2011 - 09:33 PM.
Posted 27 April 2011 - 09:49 PM
![Posted Image](http://i794.photobucket.com/albums/yy222/samsernie/stbotolphs.jpg)
![Posted Image](http://i794.photobucket.com/albums/yy222/samsernie/new%20mini/medwaymonkeys.jpg)
Posted 27 April 2011 - 09:52 PM
Edited by samsfern, 27 April 2011 - 09:52 PM.
Posted 28 April 2011 - 11:14 PM
Evan.
![Posted Image](http://i847.photobucket.com/albums/ab38/EvanBrown_1977loudmini/170420117490.jpg)
![Posted Image](http://i847.photobucket.com/albums/ab38/EvanBrown_1977loudmini/170420117491.jpg)
Posted 30 April 2011 - 01:49 AM
Not really sure if they look good or not.
The Mini is pretty low to start with !
Can any of those pictured handle a standard speed bump without being embarrassed at 2mph ?
Or even a standard country road ?
And if they can't (which I suspect) then what's the point of a Mini that can't bomb down a country lane ?
"legendary handling" relies on a decent level of clearance and properly sorted geometry.
Why screw it up ?
Just a view....
Posted 30 April 2011 - 09:36 PM
Evan.
Posted 30 April 2011 - 10:06 PM
Edited by jimmyH, 30 April 2011 - 10:06 PM.
Posted 30 April 2011 - 10:44 PM
my sump guard normally gets terrorised on country lanes, where the middle of the road is raised, all good fun though
![:P](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/thumbsup.gif)
Posted 01 May 2011 - 12:57 AM
It's perfectly low enough to do what it can (uniquely) do.
You have to climb UP into a Land Rover (for every good reason) and you have to sit DOWN to get into a Mini (for every perfectly good reason).
I think the handling will always suffer if you mess with the geometry and if you lower it you
are horribly messing with the geometry.
If you favour looks over handling then fair enough but for me the handling (entertainment value) is the whole
point of the Mini so I'd stear clear (forgive the pun) of lowering the car to make it look different / strange / odd / or more likely disabled...
Set your car up properly on 10s or 12s, get the suspension sorted on rubbers or springs and it should (and will) handle better
than almost anything else on the road - it should also look "right" and as if it's about to do motoring gymnastics.
A properly set up Mini should look as if it's on the end of a VERY tightly coiled spring which is about to LET GO.....
![:P](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/ohmy.png)
Posted 01 May 2011 - 09:04 PM
Posted 01 May 2011 - 09:17 PM
![Attached File](https://www.theminiforum.co.uk/forums/public/style_extra/mime_types/gif.gif)
Posted 01 May 2011 - 09:20 PM
Posted 02 May 2011 - 11:22 AM
![Posted Image](http://i691.photobucket.com/albums/vv274/eden7842/turbo%202/30042011527.jpg)
Posted 02 May 2011 - 04:33 PM
and just lowered my car a bit and its already on the bump stops, and thats with a fat 3 finger gap between wheel top and arch.
i see some of you here , have arches almost touching the tyres.
