Upgrading Rear Seat Belts To Inertia Type
12 replies to this topic
#1 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 27 April 2011 - 11:48 AM
Has anybody fitted the later MPI type inertia reel rear seatbelts, to an earlier model with the standard fixed rear belts? I know that the inertia reels are fitted inside the rear bins somewhere, but what extra parts would be needed other than the belts themselves and what sort of reinforcement would be needed to the inertia reel anchor point?
Any advice or guidance would be appreciated :wub: ?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 27 April 2011 - 11:59 AM
Brother in laws 1970 mini came with no rear seat belts. His written off 1990 had inertias in the rear so we've used those.
This is how we did ours
The reel we fitted onto the rear parcel shelf as far into the corners as we could get them. Used spreader plates underneath
The other end of the main belt we bolted to the rear bin with a spreader plate below the height of the seat base and as far back as poss.
The slot bit the belt plugs into bolts through the seat back behind the lower cushion in the middle again spreader plates used.
You may have to adjust the inertia reel, they are designed to work in a certain orentation, there are markings on them to show which way and how to adjust.
Edited by lrostoke, 27 April 2011 - 11:59 AM.
#3 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 27 April 2011 - 12:08 PM
Thanks for that, I think I'd preffer to have the reels tucked away in the bins out of the way, as opposed to on the parcel shelf though. :wub:
Edited by AVV IT, 27 April 2011 - 12:10 PM.
#4 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 28 April 2011 - 01:13 PM
BUMP ..... anybody else?
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 28 April 2011 - 03:36 PM
fixed mine into the wheel arch at the top of the rear bin
used a big washer on the back to spread any load, my MOT man was happy with what i had done
#6 the_r_sole
the_r_sole
  • 831 posts
Posted 28 April 2011 - 03:39 PM
i can take a pic of where they are on mine if it's any use, they are factory from 96?
#7 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 28 April 2011 - 04:06 PM
I got a set of inertia reel ones that replace the static ones and fix in the same three anchor points (on the c pillar and underneath the seats). Probably not what you're after if you want a clear parcel shelf but they are as safe as they can be and don't involve creating new anchor points. Here's a pic.
Paul
#8 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 28 April 2011 - 04:19 PM
Thanks for the responses guys
Yes that would give me an idea of where they are supposed to be mounted :)
#9 Midas Mk1
Midas Mk1
  • 5,758 posts
  • Local Club: S.U.N.M.C
Posted 28 April 2011 - 04:35 PM
Remember, Mpi rear belts are 4 point, where as the before the inertia belts with 3 point, and mount to the same positions already in the car if static factory belts are fitted. I had a blonde moment last year, and bought mpi spec rear belts lol :)
Luckily I got the from Minisport, who let me exchange them for the 3 point ones, even though it was 6 months later! :w00t:
Edited by Midas Mk1, 28 April 2011 - 04:38 PM.
#10 ross k
ross k
  • 498 posts
Posted 08 June 2011 - 09:35 PM
hey guys i now its dragging this up from ages ago but if you put the real up the top like that does it all work ok thanks ross
#11 R1minimagic
R1minimagic
  • 4,660 posts
Posted 08 June 2011 - 09:39 PM
I dont imagine that would work very well, the reels are designed to be mounted at the correct angle so they work properly.
#12 ShoutforJoy
ShoutforJoy
  • 738 posts
Posted 08 June 2011 - 09:46 PM
They are designed to replace the static belts and work fine - if they didn't they wouldn't meet the required safety standards and couldn't be used. They are adjustable to work at almost any angle.
#13 R1minimagic
R1minimagic
  • 4,660 posts
Posted 08 June 2011 - 09:49 PM
I think people are talking about using the MPi ones in that fashion, not buying special replacements...
